Re: Optimizing 11.75 disk questions
[Re: Rapom65]
#1488940
08/22/13 03:33 PM
08/22/13 03:33 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Hawk or ebc pads, phenolic pistons don't transfer the heat to the calipers and fluid, and not DOT5. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Rapom65]
#1488942
08/22/13 06:30 PM
08/22/13 06:30 PM
Posts: 22,719 Bitopia
jcc
Bitopia
The biggest bang for buck in decreasing order but all very important IMO.
1. Proper pads for application 2. "fresh" high temp fluid, the emphasis is on FRESH 3. Any, even the most hokey, even temporary brake ducting. 4. Fronts are everything when you start out, backs working well get you into trouble
You can't/won't drive fast if you in the back of your mind are wondering, is this thing going to stop?
[Re: Rapom65]
#1488950
08/23/13 03:13 PM
08/23/13 03:13 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I have a set of Hawk HP Plus for track and some stockers for street. No reason to drive around with the rotor wear,dust and noise of the Hawks. The dust is so bad that the wheels are toast after about 20 decent stops. I have Viper calipers so pad swaps add about 10 minutes to the time it takes to get your front tires off.
Mopar to the bone!!!
[Re: 72Swinger]
#1488952
08/23/13 10:56 PM
08/23/13 10:56 PM
Posts: 86 Battle Ground, Washington
Rapom65
72 Swinger I'm head over heals in L-U-V with your car. One of a select few inspiration cars for my project.
Time to get some calipers ordered up and get some progress made on this pig. So far the input has been very helpful. I need to figure out what pads I want to try on the street 1st, going to be awhile before I'll need a race set.
[Re: Rapom65]
#1488954
08/27/13 11:21 PM
08/27/13 11:21 PM
Posts: 6,516 Santa Cruz, California
Lefty
1) brake pads, not overly concerned about dust
EBC yellow stuff or Hawk HPS are the best by far in a street driven car imo. I prefer the yellow stuff, but that's just what I'm used to, not necessarily better.
MOST important is to follow the MFG's instructions for prepping rotors and pad breaking procedure.
[Re: Rapom65]
#1488957
08/27/13 11:34 PM
08/27/13 11:34 PM
jcc
Bitopia
Thanks Fury. I finally made a decision and ordered up some phenolic piston rebuilt calipers from Rock Auto. They have a wholesaler close out on some Wagner severe duty carbon metalic pads for $20 so I figured I'd give them a try and ordered a set.
Ah, one item slipped by me, and I can't see where anyone else picked up on it. If your brakes are getting so hot you need a phenolic piston to reduce heat transfer to a high temp fluid, a phenolic is not your solution. Yes phenolics are better insulators, and reasonably strong, but if you have a temp problem with steel/alum, you need a SS or special thermal lock design piston. I would not attempt to experiment with phenolics if stopping is important. please if someone has some different or more info on phenolic hP brake piston use, please share. I would cancel that order.
