Such a thing as TOO MUCH oil pressure
#1488808
08/22/13 12:50 AM
08/22/13 12:50 AM
Posts: 495 PA--USA
70VERT
PA--USA
My 440 makes about 90# of oil press at 1000 RPM cold and around 70# at 2000 while hot. Is this abnormal or anything I should try and rectify?
Re: Such a thing as TOO MUCH oil pressure
[Re: 70VERT]
#1488810
08/22/13 01:07 AM
08/22/13 01:07 AM
Posts: 654 MN
astrobuf
MN
Yes, in my opinion. Oil pressure is a function of pumping capacity, viscosity and clearances . If your pressure is high due to too much capacity, your wasting power. If it is too high due to high viscosity, your wasting power and risking inadequate flow, if it is due to less than spec'd clearances, you risk bearing damage.
Spec'ing a high flow pump with standard clearances often results in this situation. Don't do it.
Astrobuf
So, are you really a Rocket Scientist?
[Re: 70VERT]
#1488812
08/22/13 02:22 AM
08/22/13 02:22 AM
Posts: 30,493 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
But what does it do .... hot at 6k rpms ?..... 2 much pressure costs power turning the pump 2 much PLUS it costs power getting the excess oil off the cyl walls AND running the rotating assembly through all the oil mist and droplets ...
[Re: dOc …]
#1488813
08/22/13 08:08 AM
08/22/13 08:08 AM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
The pump is not the problem , its doing is job and the pressure will go to 1000 psi if the pump shaft could take it. Your problem could be that the relief valve is set too high. Is the engine new ? have you verified that the pressure is correct using an external gauge screwed into an oil port in the block. you may have an issue with your oil filter. You may have an engine that is tight on clearances . Is your oil gauge mechanical or electrical ? I would confirm that my readings are correct firstby install ing a gauge into an oil port leaving your own gauge in place .
[Re: 70VERT]
#1488816
08/22/13 12:49 PM
08/22/13 12:49 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I'm running 10W-30 and using a stock oil pump. The engine has been running this way for about 5000 miles. I never really questioned it becouse I always thought more was better I rarely take it over 5K but at those revs and hot it pushes about 55-60#.
That is bang on just go on with your life!
[Re: 70VERT]
#1488820
08/22/13 02:37 PM
08/22/13 02:37 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does the engine have a high-volume pump? If so, changing to a standard pump will probably bring the pressure back to normal.
[Re: 70VERT]
#1488822
08/22/13 02:58 PM
08/22/13 02:58 PM
Dodgem
Ontario, Canada
10 w 30 when I rebuilt my 440 in 83 it would go 100 cold and 85 or more hot at 2000. at the end of the 1/4 many years later would like over and always see 110 never hurt anything street or strip. In 2006 I put a Big milodon pump on and then an adjustable oil presssure regulator and now have it set so cold 2000 is 75 and hot 2000 is 75 and 7000 rpm is still 75. http://chucker54.stores.yahoo.net/milbrbadregk.htmldon't over think it just be happy you have good pressure!
[Re: Dodgem]
#1488826
08/22/13 11:20 PM
08/22/13 11:20 PM
Posts: 7,664 IN
ahy
IN
Agree. 55-60 PSI hot at speed is ideal. It is bound to be higher when cold. Just don't push it too much when cold (like any performance engine). 5W30 may ease the high OP at start up but I wouldn't sweat it. More important is to make sure you are running high zinc oil or a zinc additive with a flat tappet.
[Re: justinp61]
#1488827
08/22/13 11:39 PM
08/22/13 11:39 PM
Posts: 654 MN
astrobuf
MN
Years ago I had a 440 with a high pressure pump in it, in cold weather it would peg a 100# gauge at start up. At temperature it ran almost 75# at cruise rpms. The only oil I ever ran in it was Havoline 10-40. After beating on it for five years I rebuilt it and installed a standard pump.
High pressure and high volume pumps are two entirely different things. I high pressure pump simply has a higher rated relief spring. A high volume pump has a higher displacement volume.
Astrobuf
