Re: water pump source?
[Re: meepmeep70]
#1486761
08/19/13 04:07 PM
08/19/13 04:07 PM
RapidRobert
pump or housing? If pump I'd get a good brand 8 blade (iirc) parts house unit & add a circular anticav plate behind the vanes. You have to cut it in half then weld it behind the vanes (on a BB). If housing I heard 'source fixed the internal restriction issue. Good visual & you'll see it if it is restricted & send it back if it ain't right (no matter what the brand). Mainly just need one with the lower main nipple on the correct side for your app. It's a non wearing part so might see what's available used or what's on eBay.
[Re: meepmeep70]
#1486763
08/20/13 10:13 AM
08/20/13 10:13 AM
RapidRobert
Milodon has a very good reputation tho probably pricey. Pumps are about a trouble free part as I've ever seen & I've never had (or rarely heard of) a problem with a run of the mill parts house item
[Re: meepmeep70]
#1486764
08/20/13 06:08 PM
08/20/13 06:08 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
GMB aluminum water pump.Great quality.Got mine on Ebag.
