water pump source? #1486760
08/19/13 12:56 PM
08/19/13 12:56 PM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
i remember 440 source had some problems,adding a serpentine pulley set up and wanted to change the water while i was in there, who is making the most reliable water pumps for a 440? please thank you
Re: water pump source? [Re: meepmeep70] #1486761
08/19/13 04:07 PM
08/19/13 04:07 PM
pump or housing? If pump I'd get a good brand 8 blade (iirc) parts house unit & add a circular anticav plate behind the vanes. You have to cut it in half then weld it behind the vanes (on a BB). If housing I heard 'source fixed the internal restriction issue. Good visual & you'll see it if it is restricted & send it back if it ain't right (no matter what the brand). Mainly just need one with the lower main nipple on the correct side for your app. It's a non wearing part so might see what's available used or what's on eBay.
Re: water pump source? [Re: RapidRobert] #1486762
08/20/13 05:22 AM
08/20/13 05:22 AM
weymouth,mass.
weymouth,mass.
thank you,just looking for good water pump, housing is stock, will look to find a quality pump, wasn't sure if mildon was a good one or just order up one from summit
Re: water pump source? [Re: meepmeep70] #1486763
08/20/13 10:13 AM
08/20/13 10:13 AM
Milodon has a very good reputation tho probably pricey. Pumps are about a trouble free part as I've ever seen & I've never had (or rarely heard of) a problem with a run of the mill parts house item
Re: water pump source? [Re: meepmeep70] #1486764
08/20/13 06:08 PM
08/20/13 06:08 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
GMB aluminum water pump.Great quality.Got mine on Ebag.
Nautilus Racing-
