steering adjustment #148582
11/10/08 08:22 PM
11/10/08 08:22 PM
Bethlehem Pa.
tinman68 Offline OP
tinman68  Offline OP
Bethlehem Pa.
has anyone tried anything to tighten up the steering, not adjusting the box (mine's a 2 year old firm feel, still too loose). I thaught a steering stabelizor might help? ANY SUGGESTIONS
Re: steering adjustment [Re: tinman68] #148583
11/11/08 07:19 AM
11/11/08 07:19 AM
manual or power & is the play in the box or in the linkage
Re: steering adjustment [Re: RapidRobert] #148584
11/11/08 08:43 AM
11/11/08 08:43 AM
ive got a firm feel revbuilt TA box just installed and I have a slight amount of dead spot going straight ahead too. its not the coupler (changed it and its tight) and its not the linkages or ball joints.
I was going to call them and ask about it.
Re: steering adjustment #148585
11/11/08 01:30 PM
11/11/08 01:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It's rebuilt uses the old steering gears (or other good core gears possibly?). I don't think anyone makes new power steering gears.
Steering gear wear the most in the middle because that's where they are at most of the time. It you adjust to play out of the middle that is worn or slightly worn it will be too tight at the ends.
Re: steering adjustment [Re: autoxcuda] #148586
11/11/08 01:53 PM
11/11/08 01:53 PM
Bethlehem Pa.
tinman68 Offline OP
tinman68  Offline OP
Bethlehem Pa.
Thanks i'm not being understood. I'm not talking play or wear in box or tie rods etc. This power steering box is typical chrysler turns too easy. I'm want to make it fiie tighter / firmer. will a steering stabilizer help????
It's A stage 2 firm feel. Can't remove & send back have you ever tried to remove PS box from 440 w/ headers??
I should have purchased a rack & pinion setup.
the whole experience would be much better
Re: steering adjustment [Re: tinman68] #148587
11/11/08 01:58 PM
11/11/08 01:58 PM
You would probably have to send it back & have them recalibrate it.
Re: steering adjustment [Re: RapidRobert] #148588
11/11/08 02:21 PM
11/11/08 02:21 PM
what level firm feel did you get? I got the stage 3 and its great. Ive heard that level 1 or 2 can still feel light
