68 - 69 Hemi Water Pump Pulleys #1485435
08/17/13 12:08 AM
08/17/13 12:08 AM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
Are 1968 & 1969 426 Street Hemi water pump pulleys the same? Or are they different part numbers. Thanks in advance
Re: 68 - 69 Hemi Water Pump Pulleys [Re: Davtona] #1485436
08/17/13 12:25 AM
08/17/13 12:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
68 and 69 technically used a different water pump pulley ... but I think sometime in late 68 it changed .... The 66-68 water pump pulley is the same as all wedge motors and it had it's own special crank pulley to match the offset.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: JohnRR] #1485437
08/17/13 09:20 AM
08/17/13 09:20 AM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
69 specifically then as thats what I'm looking for is unique to a Hemi? Does not interchange with a wedge motor? 69 thru 71 the same then?? Thanks
Re: 68 - 69 Hemi Water Pump Pulleys [Re: Davtona] #1485438
08/17/13 11:17 AM
08/17/13 11:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes 69 to 71 is the same , it is reproduced. I have one that may be for sale
Re: 68 - 69 Hemi Water Pump Pulleys [Re: JohnRR] #1485439
08/18/13 09:46 PM
08/18/13 09:46 PM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
I'm being anal here as this is for an original car. I'm looking for an original Mopar made pulley not a reproduction. Which do you have? Thanks
Re: 68 - 69 Hemi Water Pump Pulleys [Re: Davtona] #1485440
08/19/13 09:46 AM
08/19/13 09:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nothing you would be interested in ...
Re: 68 - 69 Hemi Water Pump Pulleys [Re: Davtona] #1485441
08/19/13 12:39 PM
08/19/13 12:39 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
The water pump and crank pullies are Hemi unique on your '69.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: FJ5_Fish] #1485442
08/19/13 03:08 PM
08/19/13 03:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What makes them unique to 69 , I know the lower pulley will have an asymetric bolt pattern , was 70 the year change for that to symetric , I can't remember , otherwise what is unique about the 69 waterpump pulley ?
Re: 68 - 69 Hemi Water Pump Pulleys [Re: JohnRR] #1485443
08/19/13 03:18 PM
08/19/13 03:18 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
John - Just saying for his 69 - the Hemi water pump pulley is a unique Hemi part - smaller than the 440 pulley. I believe (later) 68 to 71 Hemi pullies are the same....and Hemi only
Re: 68 - 69 Hemi Water Pump Pulleys [Re: FJ5_Fish] #1485444
08/19/13 04:38 PM
08/19/13 04:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gotcha , when I answered his question the other day I let out the word "unique" when saying the pulley he wants is hemi specific .
Re: 68 - 69 Hemi Water Pump Pulleys [Re: Davtona] #1485445
08/19/13 10:24 PM
08/19/13 10:24 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I know this doesn't answer your question, but this is an original hemi water pump pulley with part number.
Maybe someone knows which year/years it is correct for?
Re: 68 - 69 Hemi Water Pump Pulleys [Re: pacifica] #1485446
08/20/13 09:33 AM
08/20/13 09:33 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I believe the 716 is the correct one for late '68 to 71 Hemi's. I'll double check my stuff but fairly certain it's the one.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: FJ5_Fish] #1485447
08/20/13 02:44 PM
08/20/13 02:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the 29 prefix tells me it's the late pulley
Re: 68 - 69 Hemi Water Pump Pulleys [Re: Davtona] #1485448
08/20/13 03:02 PM
08/20/13 03:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IIRC, the whole pulley change thing came about because of the change to the 6-vane A/C pump on the Hemi....this pump needs to turn faster so a smaller diameter WP pulley is used.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: John_Kunkel] #1485449
08/20/13 03:10 PM
08/20/13 03:10 PM
PEI Canada
chromedome426 Offline
PEI Canada
Pretty sure A/C wasn't available on a Hemi.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: chromedome426] #1485450
08/20/13 04:00 PM
08/20/13 04:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He didn't say it was , he left out the word WATER before PUMP though ...
Re: 68 - 69 Hemi Water Pump Pulleys [Re: JohnRR] #1485451
08/20/13 05:12 PM
08/20/13 05:12 PM
PEI Canada
PEI Canada
Whoops.....I mistook "6-vane A/C pump" as some type of A/C pump. I realize now that he was referring to the 6-blade A/C style water pump.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: chromedome426] #1485452
08/21/13 01:15 AM
08/21/13 01:15 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Just to add a bit to this... the pulley pictured above is an original late 68-71 Hemi water pump pulley. It is also an over-the-counter service part since it has the part # stamped in. Originals that actually came on the cars did not have the #'s.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: hemi70se] #1485453
08/21/13 02:41 PM
08/21/13 02:41 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Must have sold a lot of over the counter pulleys..
I've stripped paint off a number of pulleys only to find barely visable part numbers.
Just my dumb luck I guess.
Re: 68 - 69 Hemi Water Pump Pulleys [Re: 52savoy] #1485454
08/23/13 11:34 AM
08/23/13 11:34 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Were those all original 69-71 Hemi water pump pullies? as that was only what I was referring to.
