Re: 68 - 69 Hemi Water Pump Pulleys
[Re: Davtona]
#1485438
08/17/13 11:17 AM
08/17/13 11:17 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
69 specifically then as thats what I'm looking for is unique to a Hemi? Does not interchange with a wedge motor? 69 thru 71 the same then?? Thanks
Yes 69 to 71 is the same , it is reproduced. I have one that may be for sale
[Re: JohnRR]
#1485439
08/18/13 09:46 PM
08/18/13 09:46 PM
Posts: 92 Iowa
Davtona
Iowa
I'm being anal here as this is for an original car. I'm looking for an original Mopar made pulley not a reproduction. Which do you have? Thanks
[Re: Davtona]
#1485441
08/19/13 12:39 PM
08/19/13 12:39 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
The water pump and crank pullies are Hemi unique on your '69.
[Re: FJ5_Fish]
#1485442
08/19/13 03:08 PM
08/19/13 03:08 PM
JohnRR
U.S.S.A.
What makes them unique to 69 , I know the lower pulley will have an asymetric bolt pattern , was 70 the year change for that to symetric , I can't remember , otherwise what is unique about the 69 waterpump pulley ?
[Re: FJ5_Fish]
#1485444
08/19/13 04:38 PM
08/19/13 04:38 PM
JohnRR
U.S.S.A.
John - Just saying for his 69 - the Hemi water pump pulley is a unique Hemi part - smaller than the 440 pulley. I believe (later) 68 to 71 Hemi pullies are the same....and Hemi only
Gotcha , when I answered his question the other day I let out the word "unique" when saying the pulley he wants is hemi specific .
[Re: Davtona]
#1485445
08/19/13 10:24 PM
08/19/13 10:24 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Are 1968 & 1969 426 Street Hemi water pump pulleys the same? Or are they different part numbers. Thanks in advance
I know this doesn't answer your question, but this is an original hemi water pump pulley with part number.
Maybe someone knows which year/years it is correct for?
[Re: FJ5_Fish]
#1485447
08/20/13 02:44 PM
08/20/13 02:44 PM
JohnRR
U.S.S.A.
I believe the 716 is the correct one for late '68 to 71 Hemi's. I'll double check my stuff but fairly certain it's the one.
the 29 prefix tells me it's the late pulley
[Re: Davtona]
#1485448
08/20/13 03:02 PM
08/20/13 03:02 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
IIRC, the whole pulley change thing came about because of the change to the 6-vane A/C pump on the Hemi....this pump needs to turn faster so a smaller diameter WP pulley is used.
[Re: John_Kunkel]
#1485449
08/20/13 03:10 PM
08/20/13 03:10 PM
Posts: 409 PEI Canada
chromedome426
PEI Canada
Pretty sure A/C wasn't available on a Hemi.
[Re: chromedome426]
#1485450
08/20/13 04:00 PM
08/20/13 04:00 PM
JohnRR
U.S.S.A.
He didn't say it was , he left out the word WATER before PUMP though ...
[Re: JohnRR]
#1485451
08/20/13 05:12 PM
08/20/13 05:12 PM
chromedome426
PEI Canada
Whoops.....I mistook "6-vane A/C pump" as some type of A/C pump. I realize now that he was referring to the 6-blade A/C style water pump.
[Re: 52savoy]
#1485454
08/23/13 11:34 AM
08/23/13 11:34 AM
Posts: 2,483 Minneapolis, MN
hemi70se
Minneapolis, MN
Must have sold a lot of over the counter pulleys..
I've stripped paint off a number of pulleys only to find barely visable part numbers. Just my dumb luck I guess.
Were those all original 69-71 Hemi water pump pullies? as that was only what I was referring to.
