Can I change the Water Pump Housing on a SM Easily? #148503
11/10/08 06:02 PM
11/10/08 06:02 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I have a 75 Duster 360 with a bad coolant leak around the Water Pump Housing, is this something I can easily change in the engine bay?
If not I am not going to fix it and just wait another 4-5 months to fix it when the engine comes out for the car to get painted.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Can I change the Water Pump Housing on a SM Easily? [Re: shanker] #148504
11/10/08 06:06 PM
11/10/08 06:06 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
It's an afternoon job. Doesn't take too long
at all. Biggest pain is draining the system.
I hate the taste of anti-freeze but the neighbors dog sure loves it!
Re: Can I change the Water Pump Housing on a SM Easily? [Re: shanker] #148505
11/10/08 06:59 PM
11/10/08 06:59 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
It depends on what options it has, on the Dart I'm working on I can probably have it off within 15min no problem, if it has P/S A/C etc it will take a little while longer.
Wheres it leaking anyways? If it's out of the weep hole in the bottom of the pump its a simple job, if its leaking between the timing cover and block thats a different story.
Re: Can I change the Water Pump Housing on a SM Easily? [Re: MoparJoe] #148506
11/10/08 09:54 PM
11/10/08 09:54 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
its leaking between the Block and the timing chain cover..
how big of job would that be?
Re: Can I change the Water Pump Housing on a SM Easily? [Re: shanker] #148507
11/10/08 10:00 PM
11/10/08 10:00 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
It's a good day of work because everything has to come off the front and the balancer can be difficult if it's never been off. I would try to get another timing cover before you tear into it in case the one on it is too corroded to save, at that point you may as well throw a new timing chain on it while you're there.
Re: Can I change the Water Pump Housing on a SM Easily? [Re: MoparJoe] #148508
11/10/08 11:47 PM
11/10/08 11:47 PM
& at least check the block sealing surface of the timing cover, depends on how much down time you can afford if you need to have another one ready to go. & check the fuel pump eccentric & definitely replace the tchain.
Re: Can I change the Water Pump Housing on a SM Easily? [Re: MoparJoe] #148509
11/11/08 12:01 AM
11/11/08 12:01 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
+1 on the timing chain and all else mentioned.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Can I change the Water Pump Housing on a SM Easily? [Re: GoodysGotaCuda] #148510
11/11/08 11:27 AM
11/11/08 11:27 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
sounds like I am going to be buying a 6 pack of beer to talk my bud into coming over one day...
The engine is fairly fresh, has less than 10K on it since rebuilt about 8 years ago...
