Can I change the Water Pump Housing on a SM Easily?
#148503
11/10/08 06:02 PM
11/10/08 06:02 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
I have a 75 Duster 360 with a bad coolant leak around the Water Pump Housing, is this something I can easily change in the engine bay?
If not I am not going to fix it and just wait another 4-5 months to fix it when the engine comes out for the car to get painted.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
Re: Can I change the Water Pump Housing on a SM Easily?
[Re: MoparJoe]
#148506
11/10/08 09:54 PM
11/10/08 09:54 PM
shanker
Corpus Christi, TX
its leaking between the Block and the timing chain cover..
how big of job would that be?
[Re: MoparJoe]
#148509
11/11/08 12:01 AM
11/11/08 12:01 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It's a good day of work because everything has to come off the front and the balancer can be difficult if it's never been off. I would try to get another timing cover before you tear into it in case the one on it is too corroded to save, at that point you may as well throw a new timing chain on it while you're there.
+1 on the timing chain and all else mentioned.
[Re: GoodysGotaCuda]
#148510
11/11/08 11:27 AM
11/11/08 11:27 AM
shanker
Corpus Christi, TX
sounds like I am going to be buying a 6 pack of beer to talk my bud into coming over one day...
The engine is fairly fresh, has less than 10K on it since rebuilt about 8 years ago...
