Page 1 of 3 1 2 3
Aftermarket RB blocks? #1483217
08/12/13 11:33 AM
08/12/13 11:33 AM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
We plan on upgrading the block in our car and I thought I would ask for input and experiences from the members here.
Currently we're running a 74 factory RB block 4.25 stroke .055 overbore Callies crank and rods Diamond pistions 13.5-1 Cam Motion custom grind solid roller aprox .730 lift Out of the box Pro-Comp heads Team G intake with 1250 Dominator in a 3400 Lbs 73 Cuda It has run a best of 9.85@136.mph We knew when we built the engine the stock block would be the weak link and have been fortunate to get two seasons out of this combination by keeping the rpms down and running the car sparingly 200-250 passes the last two years.
We've finally got the funds to order the block and tweak a few things in the engine I.E. a jump in compression and some port work. We've looked at the Koleno World and Keith Black blocks. Were going for aluminum for weight savings and repair-ability. Looks like the KB has the most room to grow. I'm also wondering if we should go with the raised cam position? Any input or personal experiences would be greatly appreciated Thanks Randy
PS I'm aware of the lack of pickup in the KB block and the absence of fuel pump mounting and factory engine mounts We'll be going with a front motor plate
Re: Aftermarket RB blocks? [Re: Randy514] #1483218
08/12/13 11:49 AM
08/12/13 11:49 AM
AndyF Offline
AndyF  Offline
KB is nice if you can afford it. Picking up a World block from the local dealer is a cost effective way to go but those blocks are heavy.
Once you have a good block you'll be able to pick up a bunch of power by just just changing a few parts. That Team G intake is costing you hp and porting the heads should be good for a bunch.
Re: Aftermarket RB blocks? [Re: AndyF] #1483219
08/12/13 12:02 PM
08/12/13 12:02 PM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
Andy this car has been a mystery to everyone that sees it run LOL standard bore TeamG intake with a 2" adapter......out of the box Hooker 1-7/8 headers Out of the box Pro-Comps heads Old Mallory unilite distributor!
Re: Aftermarket RB blocks? [Re: AndyF] #1483220
08/12/13 12:05 PM
08/12/13 12:05 PM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
What intake do you recommend? Right now we shift at 6200 trap at 6500
Re: Aftermarket RB blocks? [Re: Randy514] #1483221
08/12/13 12:57 PM
08/12/13 12:57 PM
AndyF Offline
AndyF  Offline
MW port size I'd run a Super Victor intake.
Re: Aftermarket RB blocks? [Re: AndyF] #1483222
08/12/13 01:22 PM
08/12/13 01:22 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Get the the raised cam...wish I would have, when I think of possible new combos with my stuff that is the one limit that always comes up.
Re: Aftermarket RB blocks? [Re: B1MAXX] #1483223
08/12/13 04:38 PM
08/12/13 04:38 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Has anyone seen the HP Performance block? They were at the nats and looks like a great block!
Casey
Re: Aftermarket RB blocks? [Re: Randy514] #1483224
08/12/13 08:28 PM
08/12/13 08:28 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Another vote for KB
"These go to eleven", Nigel Tufnel
Re: Aftermarket RB blocks? [Re: Randy514] #1483225
08/12/13 09:02 PM
08/12/13 09:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since you want to buy new.... KB alum is the one
Re: Aftermarket RB blocks? [Re: MR_P_BODY] #1483226
08/12/13 09:20 PM
08/12/13 09:20 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
KB
2011 Drag Pak Challenger
Re: Aftermarket RB blocks? [Re: MR_P_BODY] #1483227
08/13/13 12:23 AM
08/13/13 12:23 AM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Whats rong with the Indy MAXX block? 4 bolts on all mains.
Is it not a good block?
Re: Aftermarket RB blocks? [Re: MR_P_BODY] #1483228
08/13/13 07:55 AM
08/13/13 07:55 AM
FL
74-440Charger Offline
FL
Any idea on pricing, and availability of his aluminum 440 block?
Re: Aftermarket RB blocks? [Re: 74-440Charger] #1483229
08/13/13 08:05 AM
08/13/13 08:05 AM
gregsdart Offline
gregsdart  Offline
About every post on blocks here the majority points to the KB.
Aluminum is the way to go, and that is my biggest regret; not going aluminum when I had the chance. At about where you are at, you can't get a better weight savings much cheaper than the $$ difference between aluminum and steel.
Re: Aftermarket RB blocks? [Re: Whompin_Wedge] #1483230
08/13/13 08:14 AM
08/13/13 08:14 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Casey
I have two waiting for me to pick up, one water block and one solid. My solid block was there on display with the raised 55mm cam tunnel, it is for my Dart.
David will make anyone the block in wedge config, he just needs to fill some back orders first. Turn around is about 2 weeks per block.
Re: Aftermarket RB blocks? [Re: Defbob] #1483231
08/13/13 09:44 AM
08/13/13 09:44 AM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
Well after talking to the builder and weighing the pros and cons we decided on the World products aluminum block. The KB was a fine piece. The KB can go to 667 Cubic inches, but requires an external oiling system (no provision for a sump) The cost was 5700.00 750.00 for the oil pump (which may have clearance problems with stock k-frames) plus shipping.They said horsepower in the range of 2000 was not out of the realm for this block! They were very friendly on the phone and informative. Turn around time was 12 weeks from order.
Now the reasons we went with the World. We have a certain budget for this build. We knew going forward that we had to upgrade the rockers (been using Pro-Comp rockers!) Have to have headers made, port the heads,Jesel belt drive, yada yada yada. The builder explained that the World Products is a quality piece, granted it can only grow to 630 ci's, but has a provision for an internal pickup. The World aluminum block came in at 4500 shipped. Twelve week turn around. The cost difference will help offset the cost of other components. Its gonna be a long time before we ever approach the power levels the KB block can withstand!
We are going with the raised cam position. Upping the compression from 13.5 to 15.0 to 1 Porting the heads Super Victor intake. Custom headers (something a little bigger then 1-7/8 LOL)
I'll come back and let you know how things go with the build Randy
Re: Aftermarket RB blocks? [Re: Defbob] #1483232
08/13/13 09:47 AM
08/13/13 09:47 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
KB if you have the time to spare & $$
Indy Max would be my second choice, just purchase it thru one of their dealers.
In my dealings with World Products, I will effectively say, they match Indy for horrible customer service and $hitty attitude...And I will NEVER buy anything again with their logo on it, keep it I don't need the issues or the attitude that comes with it!
Re: Aftermarket RB blocks? [Re: Randy514] #1483233
08/13/13 12:11 PM
08/13/13 12:11 PM
AndyF Offline
AndyF  Offline
Randy,
Read my "514 on the dyno" thread when you get a chance. I've already been down the road that you're taking. I used a World iron block but the rest if fairly similiar. If you read that thread carefully and look at the pictures you'll get some ideas.
Re: Aftermarket RB blocks? [Re: AndyF] #1483234
08/13/13 01:23 PM
08/13/13 01:23 PM
I'm a naysayer when it comes to N/A motors and aluminum blocks do to the inherit problems on ring seal They won't hold as good as ring seal as the cast grey iron, high nickel and compact graphite iron will The iron blocks are heavier, 325 lbs.+
Re: Aftermarket RB blocks? [Re: Cab_Burge] #1483235
08/13/13 01:42 PM
08/13/13 01:42 PM
Dragula Offline
Dragula  Offline
I will call you on that one...There have been dyno sessions where they made MORE power with the aluminum block. LMS if I can find it.
Re: Aftermarket RB blocks? [Re: Cab_Burge] #1483236
08/13/13 02:14 PM
08/13/13 02:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I remember talking to Jason Pettis about this very same deal and he agreed the iron was better at making more power for these and other reasons but obviously heavier and harder if not impossible to repair if the damage was bad enuff...........
Page 1 of 3 1 2 3
