Short Spark Plugs For 440 #1480251
08/05/13 09:10 PM
08/05/13 09:10 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
What brand and part number short plugs should I run in my 73 440 hp?
It's got factory electronic ignition with an aftermarket distributor.
Re: Short Spark Plugs For 440 [Re: elmor353] #1480252
08/05/13 10:00 PM
08/05/13 10:00 PM
Probally not out there, are thay the standard 14MM 5/8 reach spark plugs now or are they the tapered seat plugs from a industrial or motorhome motor? You said 1973 440 HP so I would assume there the stanard old type production plugs like the Champion RJ12YC or RJ14YC, yes? If so Accel may have one part number that may work, maybe not Sorry I can't help anymore than that
Re: Short Spark Plugs For 440 [Re: Cab_Burge] #1480253
08/05/13 10:19 PM
08/05/13 10:19 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
They are the standard 14mm, 5/8 reach plugs.
Re: Short Spark Plugs For 440 [Re: elmor353] #1480254
08/05/13 10:59 PM
08/05/13 10:59 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
NGK 7177 7355 if it is 3/8 reach
Re: Short Spark Plugs For 440 [Re: ek3] #1480255
08/06/13 01:21 AM
08/06/13 01:21 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Is there an Autolite equivalent?
Re: Short Spark Plugs For 440 [Re: elmor353] #1480256
08/06/13 02:22 AM
08/06/13 02:22 AM
My bad on the thread lengths, I'm sure that they are 3/8, not 5/8 when you say short length are you talking about the length that screws into the head or the length of the porclyn that the spark plug wires slide onto There where, are, some made that are shorter on the outside to clear headers, thats the ones I was thinking about. I use to use Autolite #74,73 and 72 non resitor plugs for drag racing, those would be AR72,AR73 and so on now. The same heat range Autolite resitor plug numbers are #85,84,83 and so on for the same heat range as the racing plugs now
Re: Short Spark Plugs For 440 [Re: Cab_Burge] #1480257
08/06/13 06:41 AM
08/06/13 06:41 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
I was looking on the Autolite website and they say that the AR73 and AR72 plugs are not shorty plugs. I'm hoping to find something in Autolite or an equivalent, because I can't afford $8.00 a piece for NGK 7177 plugs right now. The Autolite's are less than half the price of NGK's. This is a driver at the moment and it's causing me headaches to have it laid up. I have new wires to put on it, but don't want to install them without more clearance, because I don't want to take the chance of burning up the boots on the new wires. I bought wires with 90 degree boots instead of straight ones like were on it. Right now money is REALLY tight, but I need this rig to drive. Yeah, I know,waa. lol
Re: Short Spark Plugs For 440 [Re: elmor353] #1480258
08/06/13 08:10 AM
08/06/13 08:10 AM
SE PA
Yellow Fever Offline
SE PA
Re: Short Spark Plugs For 440 [Re: Yellow Fever] #1480259
08/06/13 08:15 AM
08/06/13 08:15 AM
SE PA
SE PA
Jegs will price match with free shipping!
http://www.jegs.com/i/Accel+Spark+Plugs/111/0416S-4/10002/-1
Re: Short Spark Plugs For 440 [Re: elmor353] #1480260
08/06/13 08:51 AM
08/06/13 08:51 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Standard plugs shouldn't be any problem.
Is this because of headers or missing heat shields?
Re: Short Spark Plugs For 440 [Re: Yellow Fever] #1480261
08/06/13 06:16 PM
08/06/13 06:16 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I appreciate your input, but the plugs that you are showing are .750 reach. I have stock heads and the plugs are approximately .375 reach.
Re: Short Spark Plugs For 440 [Re: elmor353] #1480262
08/06/13 06:17 PM
08/06/13 06:17 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
This is because of headers.
Re: Short Spark Plugs For 440 [Re: elmor353] #1480263
08/06/13 07:04 PM
08/06/13 07:04 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Has anyone ever used Accel 0437S-4 spark plugs? Jeg's is showing them to fit big Mopars as well as a whole s**tload of GM stuff.
Re: Short Spark Plugs For 440 [Re: elmor353] #1480264
08/06/13 07:52 PM
08/06/13 07:52 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Why make it hard ???...It's a 73 440...I'd go to the local parts store and get a set of champion RJ12YC plugs and would'nt look back... Only other advice I could give is to OPEN every box and check the tip to make sure it's centered and intact...Quality control has'nt been the greatest lately but if you hand pic them in person it eliminates the problem...That's what I do...
Re: Short Spark Plugs For 440 [Re: screamindriver] #1480265
08/06/13 09:44 PM
08/06/13 09:44 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I have a set of RJ12YC plugs. They put my spark plug wire boots too close to my headers and I've fried 4 already. This is why I'm looking to use a shorty plug. I bought new wires with 90 degree boots instead of straight boots, but I still have a clearance issue. Don't want to replace wires every week.
Re: Short Spark Plugs For 440 [Re: elmor353] #1480266
08/06/13 10:43 PM
08/06/13 10:43 PM
E
ek3 Offline
ek3  Offline
E
In an Autolite plug .. # FRM 295 is listed as the only short racing plug for 440 eng. it is 1.97 ea at summit.
Re: Short Spark Plugs For 440 [Re: elmor353] #1480267
08/06/13 11:21 PM
08/06/13 11:21 PM
Harrisburg, Pa.
Harrisburg, Pa.
Can you dimple the header tube to gain clearance for the boots ??
I've learned to mock up the headers,plugs etc... and massage the tubes where it's needed to avoid the headache after the install...I know it's not helping you now but clearancing the tube is still probably the best solution and does'nt cost anything but time...
Re: Short Spark Plugs For 440 [Re: screamindriver] #1480268
08/07/13 01:11 AM
08/07/13 01:11 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
Yeah, I tried that, but the guy I bought the truck from welded the whole exhaust system. No bolt on, welded the pipes right to the header. I'd have to cut up my exhaust system to get the headers out.
I just bought a set of Accel 437S. My local O'Reilly's had them in an 8 pack #8197. Bought them cheaper than I could get them from Jeg's or Summit and I didn't have to wait 5 days for them to get here or pay for shipping. They are about 3/8" shorter overall than RJ12YC's and Autolite 85's. Should give me the extra clearance I need with the 90 degree boots. Thanks all you guys for your input and suggestions.
