Re: Short Spark Plugs For 440
[Re: elmor353]
#1480256
08/06/13 02:22 AM
08/06/13 02:22 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
My bad on the thread lengths, I'm sure that they are 3/8, not 5/8 when you say short length are you talking about the length that screws into the head or the length of the porclyn that the spark plug wires slide onto There where, are, some made that are shorter on the outside to clear headers, thats the ones I was thinking about. I use to use Autolite #74,73 and 72 non resitor plugs for drag racing, those would be AR72,AR73 and so on now. The same heat range Autolite resitor plug numbers are #85,84,83 and so on for the same heat range as the racing plugs now
[Re: elmor353]
#1480260
08/06/13 08:51 AM
08/06/13 08:51 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I have new wires to put on it, but don't want to install them without more clearance, because I don't want to take the chance of burning up the boots on the new wires.
Standard plugs shouldn't be any problem. Is this because of headers or missing heat shields?
[Re: elmor353]
#1480267
08/06/13 11:21 PM
08/06/13 11:21 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I have a set of RJ12YC plugs. They put my spark plug wire boots too close to my headers and I've fried 4 already. This is why I'm looking to use a shorty plug. I bought new wires with 90 degree boots instead of straight boots, but I still have a clearance issue. Don't want to replace wires every week.
Can you dimple the header tube to gain clearance for the boots ?? I've learned to mock up the headers,plugs etc... and massage the tubes where it's needed to avoid the headache after the install...I know it's not helping you now but clearancing the tube is still probably the best solution and does'nt cost anything but time...
