header gasket update #1478744
08/03/13 09:37 AM
08/03/13 09:37 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Well after putting in the Percy's and wrestling with the exhaust for like 2 hours (guy welded EVERYTHING even after I said DON'T weld the mufflers in) anyway the drivers side STILL leaks. So I'll have to pull it off and re-weld the tubes for a better seal SHHHHHHHHHHHHHIIIIIIIIIIIIIIIIIIIIIIIIIIII.............
Coming soon!!!!
Re: header gasket update [Re: Mr.Yuck] #1478745
08/03/13 10:28 AM
08/03/13 10:28 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Remflex.com
They seal issues like that.
Re: header gasket update [Re: DJVCuda] #1478746
08/03/13 12:04 PM
08/03/13 12:04 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Remflex.com
what makes them different than the soft aluminum? I just asking because if there isn't enough weld to seal the aluminum how is the stel going to be any better?
Coming soon!!!!
Re: header gasket update [Re: Mr.Yuck] #1478747
08/03/13 12:17 PM
08/03/13 12:17 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Best header gaskets ive ever used where the ones that came with my TTI headers.
Or you can try permatex ultra copper sealer with the gaskets.
On my w5 motor the permatex was all i used.
Re: header gasket update [Re: Mr.Yuck] #1478748
08/03/13 03:35 PM
08/03/13 03:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve tried those gimic metal gaskets and unless the flanges are perfectly flat they leak. I use the blue Fel-pros w/grease and they never leak.
Re: header gasket update [Re: Mr.Yuck] #1478749
08/03/13 03:43 PM
08/03/13 03:43 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
A buddy had a small block on the dyno with a cheap set of headers. The headers were drilled too low so they had a gap at the bottom of all the ports. We are talking about an 1/8" gap where you can see inside the exhaust port. Junk headers
He went through a Few sets and then I gave him my set of remflex . They sealed it. And never showed any signs of fatigue.
Post a pic but if your issu is at the sealing surface it will seal.
Re: header gasket update [Re: DJVCuda] #1478750
08/03/13 04:26 PM
08/03/13 04:26 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thump I had fel-pros 1st... these are 2" hooker supercomps not real cheap. I had a set of hedmans leak, I had to re-weld them and hit them w/ a belt sander.. My circle track buddy swears by a glob of Copper RTV and let it rip
Re: header gasket update [Re: Mr.Yuck] #1478751
08/03/13 04:52 PM
08/03/13 04:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So the Fel-pros did`t work 4 u? Let me clarify; I tried the copper gaskets and they leaked bad.............never tried the Piercys...
Re: header gasket update [Re: Mr.Yuck] #1478752
08/03/13 05:05 PM
08/03/13 05:05 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The copper gaskets don't seal worth a darn. The Percy aluminum have worked for me on the 500" motor with old Hooker 2" supercomp headers.
On the 505" motor with the TTI 1-7/8" headers, I used the Percy carbon fiber gaskets. They seem to be holding up well, but the TTI headers have a better flange than the Hooker headers, so I don't know if the Carbon Fiber gaskers would work on the Hooker headers as well?
Re: header gasket update [Re: DJVCuda] #1478753
08/03/13 05:13 PM
08/03/13 05:13 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Remflex.com
X2
"These go to eleven", Nigel Tufnel
Re: header gasket update [Re: blownEFI] #1478754
08/03/13 06:21 PM
08/03/13 06:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mr Gasket Ultras.Thats all we use.Mine were on for 9 years and now with the new heads 4 or 5 years.No leaks ever We run them on all the cars with headers.My kids truck I had them on and off 3 times and still they sealed.Rocky
Chrysler Firepower
Re: header gasket update [Re: therocks] #1478755
08/03/13 07:19 PM
08/03/13 07:19 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
99% of exhaust leaks from headers does not come from poor gaskets.
Warped flanges that do not lay flat against the head are #1. The simplest solution is to split the flanges between each cylinder. That way you pull down one cylinder at a time with no interference from adjacent tubes. As long as each tube's weld is flat it will seal fine.tubes with surfaces not parallel to the others are the cause of leaks
home of the
Sox and Martin Hemi Duster
Re: header gasket update [Re: HEMIFRED] #1478756
08/03/13 08:59 PM
08/03/13 08:59 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
I use the Percys dead soft aluminum seal 4 good gaskets.
Ive even reused them and they still work great.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: header gasket update [Re: HEMIFRED] #1478757
08/03/13 09:01 PM
08/03/13 09:01 PM
MICHIGAN
MICHIGAN
Re: header gasket update [Re: BB65Barracuda] #1478758
08/03/13 09:08 PM
08/03/13 09:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Roadhazard's header gaskets are very nice, now I need to talk him into making them for 360-1s
Re: header gasket update [Re: Quicktree] #1478759
08/03/13 09:17 PM
08/03/13 09:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Didn`t know he made those............they will be my next choice since his valve cover gaskets rock.........
Re: header gasket update [Re: Thumperdart] #1478760
08/04/13 09:12 AM
08/04/13 09:12 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks Tony
Thanks Dom! Guess the valve cover gaskets are still working "OK" after a few years
Hemifred has brought up the important points. The flange should always be checked for flatness and quality of finish for the welded sealing beads.
Mr.Yuck, seems you are having some serious issues with getting yours sealed. And from what I gathered your exhaust guy welded everything together and now your stuck with not being able to get them back out to fix the flanges??
If so get yourself some Remflex gaskets ($$$$) they will conform some and seal a flange that is less than ideal
Same base material as I use but these are about 3 times thicker and don't have a perforated steel carrier. So check your clearances for using a thicker gasket in your application
Re: header gasket update [Re: HEMIFRED] #1478761
08/04/13 10:29 AM
08/04/13 10:29 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
these are cut... don't see how you can cut between 3/5 thou (were the leak is).
Roadhaz... I don't mind the $43 for the Rem's I just don't want to put off what might need to be done anyway. The 1st set of Fel-pro 1414's lasted a good 100+ miles and were fine until the 5 run of the night when I noticed a slight leak, 2nd round of elims blew it all the way out. The percy's leaked at 1st start up. FWIW they seem to be blowing out at the top on 3/5...pass side still has the original Fel-pro 1414's.
Re: header gasket update [Re: Mr.Yuck] #1478762
08/04/13 10:32 AM
08/04/13 10:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Metal expands when heated.. we all know this... so
give it the room to expand and dont let it warp the
flanges... if you give each tube a slip area it will
slip instead of warping.. by that I mean drill one
of the mounting holes larger(per tube).. if you have
3 holes per tube drill out 2 of the holes to slide..
you keep 1 hole to locate the tubes..I like
a gragfoil (graphite on stainless material) to let
it slide easy... cut each flange from each other
(ends are cut from the center tubes)... all it takes
for a leak is just a small amount of compression loss
at the flange to get it started and it progressively
gets worse with each heat cycle... cheapo (thin) flanges
make it much easier to warp... thats why I use 3/8"
flanges on all the headers I build
Re: header gasket update [Re: MR_P_BODY] #1478763
08/04/13 10:38 AM
08/04/13 10:38 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Heat wasn't an issue this time as it leaked from frist fire up. These are pretty thick, they are Hooker Supercomps. They are 2 piece and 1-3 flange is cut and 7 is t he slip-fit tube. But I'll try and drill one hole a tad bigger on the 3 side of the header.
