Andy F modern MC adapter in A-body #1476265
07/29/13 11:41 PM
07/29/13 11:41 PM
Detroit, MI
CokeBottleKid Offline OP
Detroit, MI
So I have an A-body with factory manual brakes, I've done the conversion on other cars but always been power. What master cylinder do I need to get with the adapter? Looking for one with a 15/16 bore. Also is an adjustable rod necessary or not?
Re: Andy F modern MC adapter in A-body [Re: CokeBottleKid] #1476266
07/30/13 12:25 AM
07/30/13 12:25 AM
An '89 Dakota has a 15/16" bore alum M/C but I do not know if it has the recess inside the rear piston recess "thimble" which is REQUIRED for a manual brake app. An alum M/C has either a thinner flange or the piston is closer to the flange (#2 iirc) which will want a shorter pushrod but the adapter moves the whole shebang forward which makes up for some (or all) of that distance. With the right (with the recess) M/C I would mock it up & go from there. There are several lengths of OE manual brake pushrods available
Re: Andy F modern MC adapter in A-body [Re: CokeBottleKid] #1476267
07/30/13 12:51 AM
07/30/13 12:51 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Dr Diff sells the MC and adapter as a whole (kit). I'm not sure if a manual pushrod works; however, I bought an adjustable one from him for myself. I'm in the process of doing this swap. Just need to repair my firewall.
Re: Andy F modern MC adapter in A-body [Re: MuuMuu101] #1476268
07/30/13 07:14 AM
07/30/13 07:14 AM
East Tennessee
Burkenator Offline
Burkenator  Offline
East Tennessee
My Dr. Diff kit worked great with my original manual pushrod. Did not even need to adjust to make my brake lights work correctly.
Re: Andy F modern MC adapter in A-body [Re: CokeBottleKid] #1476269
07/30/13 11:59 AM
07/30/13 11:59 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, no off-the-shelf, 15/16" bore aluminum master cylinder will fit a manual brake application.
As far as I know, I'm the only source for the master. I'm currently out, but the machine shop is working on another batch.
Re: Andy F modern MC adapter in A-body [Re: Burkenator] #1476270
07/30/13 12:00 PM
07/30/13 12:00 PM
AndyF Offline
AndyF  Offline
That is the way it is designed to work!
Re: Andy F modern MC adapter in A-body [Re: DoctorDiff] #1476271
07/30/13 12:49 PM
07/30/13 12:49 PM
Detroit, MI
Detroit, MI
How come on your website it states for B/E only?
Re: Andy F modern MC adapter in A-body [Re: CokeBottleKid] #1476272
07/30/13 01:23 PM
07/30/13 01:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
On this note, why not just run a 15/16" four bolt M/C? Other than the slight weight savings I don't see the benefit of the 2 bolt setup. I did check out Rock Auto to price a 4 bolt unit, about $30 for a new Raybestos Professional one.
Don't be the exception.
Re: Andy F modern MC adapter in A-body [Re: CokeBottleKid] #1476273
07/31/13 02:11 AM
07/31/13 02:11 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As far as I know, my website lists A, B, and E body applications:
* 4 Hole for all A-Bodies and B/E-Bodies w/power brakes
* 4 Stud for B/E Bodies w/manual brakes
Re: Andy F modern MC adapter in A-body [Re: DoctorDiff] #1476274
08/01/13 01:11 AM
08/01/13 01:11 AM
Detroit, MI
Detroit, MI
Exactly, why no 4 stud for A-body with manual brakes... why is it different than B or E?
Re: Andy F modern MC adapter in A-body [Re: CokeBottleKid] #1476275
08/01/13 03:20 AM
08/01/13 03:20 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A 4 stud adapter does not fit manual brake equipped A-bodies because the studs are mounted in the firewall.
