Re: Andy F modern MC adapter in A-body
[Re: CokeBottleKid]
#1476266
07/30/13 12:25 AM
07/30/13 12:25 AM
RapidRobert
An '89 Dakota has a 15/16" bore alum M/C but I do not know if it has the recess inside the rear piston recess "thimble" which is REQUIRED for a manual brake app. An alum M/C has either a thinner flange or the piston is closer to the flange (#2 iirc) which will want a shorter pushrod but the adapter moves the whole shebang forward which makes up for some (or all) of that distance. With the right (with the recess) M/C I would mock it up & go from there. There are several lengths of OE manual brake pushrods available
[Re: Burkenator]
#1476270
07/30/13 12:00 PM
07/30/13 12:00 PM
Posts: 31,061 Oregon
AndyF
My Dr. Diff kit worked great with my original manual pushrod. Did not even need to adjust to make my brake lights work correctly.
That is the way it is designed to work!
[Re: DoctorDiff]
#1476271
07/30/13 12:49 PM
07/30/13 12:49 PM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
Unfortunately, no off-the-shelf, 15/16" bore aluminum master cylinder will fit a manual brake application.
As far as I know, I'm the only source for the master. I'm currently out, but the machine shop is working on another batch.
How come on your website it states for B/E only?
[Re: CokeBottleKid]
#1476272
07/30/13 01:23 PM
07/30/13 01:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
On this note, why not just run a 15/16" four bolt M/C? Other than the slight weight savings I don't see the benefit of the 2 bolt setup. I did check out Rock Auto to price a 4 bolt unit, about $30 for a new Raybestos Professional one.
[Re: DoctorDiff]
#1476274
08/01/13 01:11 AM
08/01/13 01:11 AM
CokeBottleKid
Detroit, MI
As far as I know, my website lists A, B, and E body applications:
* 4 Hole for all A-Bodies and B/E-Bodies w/power brakes
* 4 Stud for B/E Bodies w/manual brakes
Exactly, why no 4 stud for A-body with manual brakes... why is it different than B or E?
