The 484 pump gas Hemi is starting to come around.... #1475508
07/28/13 11:00 PM
07/28/13 11:00 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Finally got some good solid passes out of it this weekend...I still think I am down on Hp more than I want to be, but I got a 10.84 at 124.7 out of it...1.51 60ft still spinning...It was street car night TNT and they had water almost to the line. Was lucky it hooked that good. Started out with a 10.90, but hit the rev limiter on the shifts. Its a really old 7k chip and is way off as I was know where near 7k. Put a 7300 in it, bam 10.88....Last pass switched to the BIG squirters and 10.84....
Now I need to find a fiber glass shaker hood and drop another 1/10 off my ET...
Re: The 484 pump gas Hemi is starting to come around.... [Re: Dragula] #1475509
07/28/13 11:04 PM
07/28/13 11:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Cool!
Re: The 484 pump gas Hemi is starting to come around.... [Re: Dodgem] #1475510
07/28/13 11:09 PM
07/28/13 11:09 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks super clean, and nice.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: The 484 pump gas Hemi is starting to come around.... [Re: Dragula] #1475511
07/29/13 12:50 AM
07/29/13 12:50 AM
WA
JD Dart Offline
JD Dart  Offline
WA
You got to Love those hemi's nice
Re: The 484 pump gas Hemi is starting to come around.... [Re: JD Dart] #1475512
07/29/13 07:45 AM
07/29/13 07:45 AM
Nuther pic...
Re: The 484 pump gas Hemi is starting to come around.... [Re: Dragula] #1475513
07/29/13 07:50 AM
07/29/13 07:50 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Looks good. How do you get away with having the regulator mounted on the firewall? No EFI on this version?
Re: The 484 pump gas Hemi is starting to come around.... [Re: Jeremiah] #1475514
07/29/13 08:49 AM
07/29/13 08:49 AM
I have a JW sheild on it, and they were Ok with it. When I run EFI, the place where the regulator is now becomes a Y-block and the regulator is on the back of the intake. I left it so I could switch back. If I do, I would like to upgrade to XFI 2.0....
Re: The 484 pump gas Hemi is starting to come around.... [Re: Dragula] #1475515
07/29/13 12:28 PM
07/29/13 12:28 PM
Well, no new hood for the "Sunday at Niagara" Nostalgia weekend this weekend....
Called AAR this morning and they want 10-12 days to make the hood before shipping it. None in stock. Figured if I put a FG shaker hood on it and sealed the carb to it, I would get 1/10 out of it...Guess I should have bought one sooner.
