The 484 pump gas Hemi is starting to come around....
#1475508
07/28/13 11:00 PM
07/28/13 11:00 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
Finally got some good solid passes out of it this weekend...I still think I am down on Hp more than I want to be, but I got a 10.84 at 124.7 out of it...1.51 60ft still spinning...It was street car night TNT and they had water almost to the line. Was lucky it hooked that good. Started out with a 10.90, but hit the rev limiter on the shifts. Its a really old 7k chip and is way off as I was know where near 7k. Put a 7300 in it, bam 10.88....Last pass switched to the BIG squirters and 10.84.... Now I need to find a fiber glass shaker hood and drop another 1/10 off my ET...
Re: The 484 pump gas Hemi is starting to come around....
[Re: Dodgem]
#1475510
07/28/13 11:09 PM
07/28/13 11:09 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Looks super clean, and nice.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Jeremiah]
#1475514
07/29/13 08:49 AM
07/29/13 08:49 AM
Dragula
Looks good. How do you get away with having the regulator mounted on the firewall? No EFI on this version?
I have a JW sheild on it, and they were Ok with it. When I run EFI, the place where the regulator is now becomes a Y-block and the regulator is on the back of the intake. I left it so I could switch back. If I do, I would like to upgrade to XFI 2.0....
