Hurst Shifter - Bent Lever? #1472372
07/23/13 12:20 AM
07/23/13 12:20 AM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Looking at my first Hurst shifter. It's mated to an A833 on my 1974 Challenger. Looks like the reverse lever is bent to me. Compared it to as many pics on the net I could find, but since this is my first one I'm looking for confirmation.
Also, I took the clip off the reverse rod at the shifter lever and I'm not able to pull the rod out of the lever. Should this come right out?
Larger picture, I'm having issues with the shift getting stuck in second gear. I'm able to reset and align all the levels and it frees up and I can drive the car again for a bit...
Thanks,
-Rob
RobH
72 Plymouth Duster 360
73 Dodge Charger SE 318
74 Dodge Challenger 340-4
74 Dodge Challenger 440
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472373
07/23/13 12:31 AM
07/23/13 12:31 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yeah, that lever does look bent; can't recall a Hurst shifter lever at the tower end where the bends viewed that way were not all at 90 degrees.
Had an 833 that would jam up similar to yours: I loosened the side cover bolts, pushed the side cover upwards with a prybar and re-tightened the bolts, and that fixed it.
Re: Hurst Shifter - Bent Lever? [Re: topside] #1472374
07/23/13 09:59 AM
07/23/13 09:59 AM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Am I going to be able to bend that back while it's still on the car?
As mentioned in the initial post, I can't seem to get the rod off the level after taking out the clip. Any tricks to this? Seems like it should just pull out. Wondering if the bend is preventing it...
Thanks,
-Rob
RobH
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472375
07/23/13 11:00 AM
07/23/13 11:00 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I'd pull the shifter, disassemble, clean, grease, and straighten out that lever. Take pictures of the different levers and plates and their orientation as they come out during dis-assembly. They are pretty easy to do. You can also add a washer or two in the stack thru the large pin that everything pivots on to help remove some of the sideways slop in the gate.
Re: Hurst Shifter - Bent Lever? [Re: Sixpak] #1472376
07/23/13 12:53 PM
07/23/13 12:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks like the lever was bent to make the shift rod work.
Re: Hurst Shifter - Bent Lever? [Re: stumpy] #1472377
07/23/13 12:58 PM
07/23/13 12:58 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Looks like an A/B shifter not an E. E will have 7180 on reverse arm (the one that is bent). A/B will have 6353.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472378
07/23/13 01:22 PM
07/23/13 01:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there is a burr of some sort hanging up the rod from coming out of the lever or a part of the clip that can't be made out in that blurry picture.
Either way pull the shifter out of the car and go from there .
Re: Hurst Shifter - Bent Lever? [Re: JohnRR] #1472379
07/23/13 02:04 PM
07/23/13 02:04 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Here's a slightly better picture of the debacle...
RobH
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472380
07/23/13 02:05 PM
07/23/13 02:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should be able to put a long flat blade screw driver in there and just pop it out .
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472381
07/23/13 03:02 PM
07/23/13 03:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not really, you probably need to go with decaf.
Don't be the exception.
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472382
07/23/13 04:40 PM
07/23/13 04:40 PM
fresno ca
mikeysmopars Offline
fresno ca
That looks like the A&B body shifter
E Body has a dogleg on the outside lever
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Hurst Shifter - Bent Lever? [Re: Supercuda] #1472383
07/23/13 05:01 PM
07/23/13 05:01 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
lol - I already drink decaf
RobH
Re: Hurst Shifter - Bent Lever? [Re: 64dodge572] #1472384
07/23/13 11:08 PM
07/23/13 11:08 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Looks like the mystery is starting to unfold. Reverse lever says 6353.. so I have an A/B body shifter on my E body...
RobH
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472385
07/24/13 01:06 AM
07/24/13 01:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Looks like the mystery is starting to unfold. Reverse level says 6353.. so I have an A/B body shifter on my E body...
that is not why it wouldn't come apart.
Re: Hurst Shifter - Bent Lever? [Re: JohnRR] #1472386
07/24/13 06:13 PM
07/24/13 06:13 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Yes came apart pretty easily with a flat head driver as you suggested.
RobH
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472387
08/10/13 05:13 PM
08/10/13 05:13 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
updated photo showing progress
Replaced the shifter with a proper e-body shifter
Replaced the Reverse rod and swivel. Was bent like the R shift lever
All new clips and used washers to remove some of the play.
Thanks to Dan @ Brewers for all his help on this.
So now 1-2, 3-4 all work fine, but I can't seem to find Reverse on the new shifter.
I have the proper hurst alignment tool and I've used that to set the linkage.
Any suggestions for finding Reverse? I'm just trying to shift while in the car while it's up on the lift.
Thanks,
-Rob
RobH
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472388
08/10/13 05:15 PM
08/10/13 05:15 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
Another shot from the side of the new shifter
RobH
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472389
08/10/13 09:59 PM
08/10/13 09:59 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Disconnect the linkage and see if you can get reverse by moving the trans lever with a wrench. If you can, put both shifter and trans in reverse and adjust to that.
I can't afford this. mark
Re: Hurst Shifter - Bent Lever? [Re: a12superbee] #1472390
08/10/13 11:28 PM
08/10/13 11:28 PM
MD
rkh17 Offline OP
rkh17  Offline OP
MD
By "linkage" I'm assuming you mean the reverse rod. I can move the reverse trans lever with the linkage (reverse rod) attached. The 1-2 and 3-4 rods are in neutral position. I move the R rod manually with my hand and it goes into reverse.
Just can't seem to do the same from the shifter in the car. It feels like there is no path to R in the shifter. I'm sure it's there but something is blocking...
Re: Hurst Shifter - Bent Lever? [Re: rkh17] #1472391
08/11/13 12:40 AM
08/11/13 12:40 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Both both in reverse and make sure the rod is adjusted properly.
You mentioned you had the tool to line up the box, maybe your trans needs a little bit more or less.
