Hurst Shifter - Bent Lever?
#1472372
07/23/13 12:20 AM
07/23/13 12:20 AM
Posts: 36 MD
rkh17
MD
Looking at my first Hurst shifter. It's mated to an A833 on my 1974 Challenger. Looks like the reverse lever is bent to me. Compared it to as many pics on the net I could find, but since this is my first one I'm looking for confirmation.
Also, I took the clip off the reverse rod at the shifter lever and I'm not able to pull the rod out of the lever. Should this come right out?
Larger picture, I'm having issues with the shift getting stuck in second gear. I'm able to reset and align all the levels and it frees up and I can drive the car again for a bit...
Thanks,
-Rob
RobH -- 72 Plymouth Duster 360 73 Dodge Charger SE 318 74 Dodge Challenger 340-4 74 Dodge Challenger 440
Re: Hurst Shifter - Bent Lever?
[Re: topside]
#1472374
07/23/13 09:59 AM
07/23/13 09:59 AM
Posts: 36 MD
rkh17
MD
Am I going to be able to bend that back while it's still on the car?
As mentioned in the initial post, I can't seem to get the rod off the level after taking out the clip. Any tricks to this? Seems like it should just pull out. Wondering if the bend is preventing it...
Thanks,
-Rob
[Re: stumpy]
#1472377
07/23/13 12:58 PM
07/23/13 12:58 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Looks like an A/B shifter not an E. E will have 7180 on reverse arm (the one that is bent). A/B will have 6353.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: JohnRR]
#1472379
07/23/13 02:04 PM
07/23/13 02:04 PM
Posts: 36 MD
rkh17
MD
Here's a slightly better picture of the debacle...
[Re: rkh17]
#1472382
07/23/13 04:40 PM
07/23/13 04:40 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
That looks like the A&B body shifter E Body has a dogleg on the outside lever
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: 64dodge572]
#1472384
07/23/13 11:08 PM
07/23/13 11:08 PM
Posts: 36 MD
rkh17
MD
Looks like the mystery is starting to unfold. Reverse lever says 6353.. so I have an A/B body shifter on my E body...
[Re: rkh17]
#1472385
07/24/13 01:06 AM
07/24/13 01:06 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Looks like the mystery is starting to unfold. Reverse level says 6353.. so I have an A/B body shifter on my E body...
that is not why it wouldn't come apart.
[Re: JohnRR]
#1472386
07/24/13 06:13 PM
07/24/13 06:13 PM
Posts: 36 MD
rkh17
MD
Yes came apart pretty easily with a flat head driver as you suggested.
[Re: rkh17]
#1472387
08/10/13 05:13 PM
08/10/13 05:13 PM
Posts: 36 MD
rkh17
MD
updated photo showing progress Replaced the shifter with a proper e-body shifter Replaced the Reverse rod and swivel. Was bent like the R shift lever All new clips and used washers to remove some of the play.
Thanks to Dan @ Brewers for all his help on this.
So now 1-2, 3-4 all work fine, but I can't seem to find Reverse on the new shifter.
I have the proper hurst alignment tool and I've used that to set the linkage.
Any suggestions for finding Reverse? I'm just trying to shift while in the car while it's up on the lift.
Thanks,
-Rob
[Re: rkh17]
#1472388
08/10/13 05:15 PM
08/10/13 05:15 PM
Posts: 36 MD
rkh17
MD
Another shot from the side of the new shifter
[Re: rkh17]
#1472389
08/10/13 09:59 PM
08/10/13 09:59 PM
Posts: 6,301 colorado
a12superbee
colorado
Disconnect the linkage and see if you can get reverse by moving the trans lever with a wrench. If you can, put both shifter and trans in reverse and adjust to that.
I can't afford this.
mark
[Re: rkh17]
#1472391
08/11/13 12:40 AM
08/11/13 12:40 AM
a12superbee
colorado
Both both in reverse and make sure the rod is adjusted properly. You mentioned you had the tool to line up the box, maybe your trans needs a little bit more or less.
mark
