Re: Best Header gasket
[Re: ahy]
#1469347
07/17/13 09:10 PM
07/17/13 09:10 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
I've had good luck with Percy's aluminum ones also reused them several times. If there is a major mismatch I've used Remflex and never had any issues. ![](/ubbthreads/images/graemlins/thumbs.gif) Scott
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: aspenrt360]
#1469350
07/17/13 11:40 PM
07/17/13 11:40 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
best header gaskets I have ever used are Percy's the thick aluminum ones I have reused them on different heads and headers and never had a leak.
X2.. I've used Percy's on my 383 & after the first heat cycle retorque, they seal great.
[Re: WayneM]
#1469352
07/18/13 12:46 AM
07/18/13 12:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I can tell you how to minimize any leaks.. if the flange is 1 piece cut the end tubes from the center (wedge) and open up 1 of the mounting hole per tube so it can slide and not buckle the flange... I like any gasket thats part graphite.. its slippery ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 77ProStreet]
#1469355
07/18/13 01:16 AM
07/18/13 01:16 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
If you have used other gaskets and they lasted like a year and then blew out, Remflex is the cure. Only thing that sucks is they get destroyed if you have to pull a header.
Mopar to the bone!!!
[Re: 72Swinger]
#1469356
07/18/13 01:33 AM
07/18/13 01:33 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: BigDaddy440]
#1469359
07/18/13 05:15 AM
07/18/13 05:15 AM
Posts: 815 Alexandria, NJ
WayneM
Alexandria, NJ
Thanks Guys! I agree that the quality of the header itself is a major factor. I'll never forget the first set I had so many years ago- dented up junk from englishtown swap meet, where I had to change gaskets weekly. Hey- I had it down to a science and did it in a parking lot anywhere. ![](/ubbthreads/images/graemlins/laugh2.gif) What is the remflex made of?
2014 Durango R/T 2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed 1998 Dodge Durango SLT 5.2 1971 Plymouth Duster- <<<<<MOPAR SPOKEN HERE>>>>>
