Best Header gasket #1469341
07/17/13 05:29 PM
07/17/13 05:29 PM
Alexandria, NJ
WayneM Offline OP
WayneM  Offline OP
Alexandria, NJ
Just got my brand spanky new W2 TTI headers (gorgeous). The gaskets that were in the box look decent. I am wondering how they are as they look like their own.
In the past, I've always had good luck with Mr. Gasket ultra seal (the graphite coated ones). I haven't used any of the new copper or fancy stuff. What say in Moparts land?
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: Best Header gasket [Re: WayneM] #1469342
07/17/13 06:41 PM
07/17/13 06:41 PM
Sioux Falls, SD
Matt Butler Offline
Matt Butler  Offline
Sioux Falls, SD
I just put my 360 back together after a head gasket failure and I am using the REMFLEX gaskets from Mancini... This is the best my headers have ever sealed! Great crush on the gasket and small imperfections in the flange don't bother them.
Re: Best Header gasket [Re: Matt Butler] #1469343
07/17/13 07:12 PM
07/17/13 07:12 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
best header gaskets I have ever used are Percy's the thick aluminum ones I have reused them on different heads and headers and never had a leak.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Best Header gasket [Re: aspenrt360] #1469344
07/17/13 07:32 PM
07/17/13 07:32 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
You're going to laugh but I have had good results just coating the cheap paper Mr Gasket type ones that come with most header kits with hi temp silicone ( the red stuff or copper stuff) and call it done. Unless the bolts loosen up and cause a blow out they do a good job on my junk.
If you have 3/8" machined flanges just use the silicone, no gasket.
Kevin
Re: Best Header gasket [Re: Twostick] #1469345
07/17/13 08:43 PM
07/17/13 08:43 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Great question!
I will be soon installing my 440 w/stealth heads, Tri-y's, 727 and "K" frame as an assembly from the bottom, lowering the car down over it. It would really suck if I were to develop a exhaust leak. Someone out there has the answer.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Best Header gasket [Re: Copper Dart] #1469346
07/17/13 08:52 PM
07/17/13 08:52 PM
IN
ahy Offline
ahy  Offline
IN
Best for me is no gasket. Just high temp RTV. When the TTI gasket installed originally started to leak I repaired with RTV only. No problems for 3 years. With metal to metal contact or at most a thin layer of RTV there is nothing to blow out.
Re: Best Header gasket [Re: ahy] #1469347
07/17/13 09:10 PM
07/17/13 09:10 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I've had good luck with Percy's aluminum ones also reused them several times. If there is a major mismatch I've used Remflex and never had any issues.
Scott
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Best Header gasket [Re: WayneM] #1469348
07/17/13 09:37 PM
07/17/13 09:37 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Remflex are real nice,but tough as hell to cut to size,which is what i had to do to match my exhaust ports.They do make em specific for W2 but not indy 360-1's.The gaskets indy gave me with the heads lasted 1 heat cycle and nothing left but screen
Re: Best Header gasket [Re: WayneM] #1469349
07/17/13 09:39 PM
07/17/13 09:39 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: Best Header gasket [Re: aspenrt360] #1469350
07/17/13 11:40 PM
07/17/13 11:40 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
X2.. I've used Percy's on my 383 & after the first heat cycle retorque,
they seal great.
Re: Best Header gasket [Re: WayneM] #1469351
07/18/13 12:38 AM
07/18/13 12:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
the gaskets that came with your headers are good gaskets. i'v never had a problem with them in the 10yrs i'v used them.
Re: Best Header gasket [Re: WayneM] #1469352
07/18/13 12:46 AM
07/18/13 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I can tell you how to minimize any leaks.. if the flange
is 1 piece cut the end tubes from the center (wedge)
and open up 1 of the mounting hole per tube so it can
slide and not buckle the flange... I like any gasket
thats part graphite.. its slippery
Re: Best Header gasket [Re: MR_P_BODY] #1469353
07/18/13 01:07 AM
07/18/13 01:07 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
My experience tells me that high dollar header gaskets are bandaids for bad header flanges. If the header is good, any gasket should seal it. Brand new TTI's.... A piece of cardboard should work.
Re: Best Header gasket [Re: MR_P_BODY] #1469354
07/18/13 01:07 AM
07/18/13 01:07 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I have had GREAT success with Remflex. First time on my motorhome, lots of heat...no leaks.
Re: Best Header gasket [Re: 77ProStreet] #1469355
07/18/13 01:16 AM
07/18/13 01:16 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If you have used other gaskets and they lasted like a year and then blew out, Remflex is the cure. Only thing that sucks is they get destroyed if you have to pull a header.
Mopar to the bone!!!
Re: Best Header gasket [Re: 72Swinger] #1469356
07/18/13 01:33 AM
07/18/13 01:33 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
remflex hands down!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Best Header gasket [Re: WayneM] #1469357
07/18/13 03:39 AM
07/18/13 03:39 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I don't like the TTi OE header gaskets, they are thin and don't seal well.. Personally I have used the Fel-Pros with good sucess..
Just my $0.0.2..
Re: Best Header gasket [Re: Sinitro] #1469358
07/18/13 04:11 AM
07/18/13 04:11 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Remflex has my vote.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Best Header gasket [Re: BigDaddy440] #1469359
07/18/13 05:15 AM
07/18/13 05:15 AM
Alexandria, NJ
WayneM Offline OP
WayneM  Offline OP
Alexandria, NJ
Thanks Guys! I agree that the quality of the header itself is a major factor. I'll never forget the first set I had so many years ago- dented up junk from englishtown swap meet, where I had to change gaskets weekly. Hey- I had it down to a science and did it in a parking lot anywhere.
What is the remflex made of?
2014 Durango R/T
Re: Best Header gasket [Re: WayneM] #1469360
07/18/13 08:40 AM
07/18/13 08:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have always used Fel-Pro 1414's but after 2 blew out with my new 2" headers I went w/ Percy's we shall see how the hold up. I'll be heading to the track Friday night if it isn't 100* out.
Coming soon!!!!
