Push button 727? #1467617
07/14/13 12:38 PM
07/14/13 12:38 PM
Midwest
fuseable Online rolleyes OP
fuseable  Online Rolleyes OP
Midwest
Can a ball and trunion 727 be converted to a slip yoke with a 1965 output shaft and a tail shaft housing?
Re: Push button 727? [Re: fuseable] #1467618
07/14/13 02:05 PM
07/14/13 02:05 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Why not just use a '65 trans? They aren't real cheap, but they are available.
This is the land of the free because of the brave
Re: Push button 727? [Re: rbstroker] #1467619
07/14/13 02:48 PM
07/14/13 02:48 PM
Midwest
Midwest
I have a 65 in the car now, just looking to build a spare with a ball and trunion I have laying around. I have a chance to get a 65 output shaft and tail shaft housing cheap.
Re: Push button 727? [Re: fuseable] #1467620
07/14/13 04:47 PM
07/14/13 04:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any cable shift 727 can be converted to slip yoke with a '65 tail housing, output shaft and its ball bearing..
Re: Push button 727? [Re: John_Kunkel] #1467621
07/14/13 05:38 PM
07/14/13 05:38 PM
Midwest
Midwest
Thank you John Kunkel
Re: Push button 727? [Re: John_Kunkel] #1467622
07/14/13 06:26 PM
07/14/13 06:26 PM
John does that apply to the 904 also?
Re: Push button 727? [Re: RapidRobert] #1467623
07/14/13 09:07 PM
07/14/13 09:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No cable shift 904 had a slip yoke, the 904 slip yoke didn't arrive until '66 and the '66-on tail won't fit the cable shift case.
Re: Push button 727? [Re: John_Kunkel] #1467624
07/14/13 11:48 PM
07/14/13 11:48 PM
alright, thank you John
Re: Push button 727? [Re: RapidRobert] #1467625
07/15/13 11:03 AM
07/15/13 11:03 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
You can also convert it like Nascar did by using a bolt on slip-yoke like 4 wheel drives use then install the spline on the front of the drive shaft and standard u-joint in rear. Did this on mine before I found a 65 unit to replace it.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Push button 727? [Re: Savoy1964] #1467626
07/15/13 11:11 AM
07/15/13 11:11 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I did just that on my '60 Chrysler which has a '64 727 in it...
