Re: Push button 727?
[Re: fuseable]
#1467618
07/14/13 02:05 PM
07/14/13 02:05 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Why not just use a '65 trans? They aren't real cheap, but they are available.
This is the land of the free
because of the brave
[Re: fuseable]
#1467620
07/14/13 04:47 PM
07/14/13 04:47 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Any cable shift 727 can be converted to slip yoke with a '65 tail housing, output shaft and its ball bearing..
[Re: RapidRobert]
#1467623
07/14/13 09:07 PM
07/14/13 09:07 PM
John_Kunkel
Rio Linda, CA
No cable shift 904 had a slip yoke, the 904 slip yoke didn't arrive until '66 and the '66-on tail won't fit the cable shift case.
[Re: RapidRobert]
#1467625
07/15/13 11:03 AM
07/15/13 11:03 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
You can also convert it like Nascar did by using a bolt on slip-yoke like 4 wheel drives use then install the spline on the front of the drive shaft and standard u-joint in rear. Did this on mine before I found a 65 unit to replace it.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
