340 Distributor Drive Removal #1467455
07/14/13 12:32 AM
07/14/13 12:32 AM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
Can it be done in the car without tearing the top of the engine apart? Ive tried with a magnet and pliers and no dice.
Re: 340 Distributor Drive Removal [Re: RangerDan440] #1467456
07/14/13 12:39 AM
07/14/13 12:39 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Did you turn it with a big screwdriver backwards (from normal drive direction) to get it to pop itself up? I've pulled them out once they were loose that way.
Worst comes to worst, intake manifold is not all that hard to slip off.
Re: 340 Distributor Drive Removal [Re: RangerDan440] #1467457
07/14/13 12:44 AM
07/14/13 12:44 AM
It can be done, sometimes their hard, sometimes their not I use a big screwdriver to spin them up out of the cam gear and then you can use a piece of safety wire with a noose to slide over the gear and then tighten that up like a lasso and carefully thread the wire along on eof the teeth and pull Thta is if they won't pull out easy with a pair of duckbill pliers or needle nose pliers One other option is to use a small 90 degree offset screwdriver under the gear to help pry it up, I use a set of Visegrip pliers to hold the screwdriver and pry it up very carefully Usually the shaft has some wear on it in the bushing area and once the shaft is clear of that worn spot it pops right out
Re: 340 Distributor Drive Removal [Re: Cab_Burge] #1467458
07/14/13 12:52 AM
07/14/13 12:52 AM
spinning it with a screwdriver is not an option; the groove for the distributor shaft is completely worn down and that's why it has to be replaced. I pulled the drive gear from a spare small block and it slid right out with a magnet but the one Im trying to pull is in pretty tight.
Re: 340 Distributor Drive Removal [Re: RangerDan440] #1467459
07/14/13 12:55 AM
07/14/13 12:55 AM
Good luck Try getting a big screwdriver with a really thick tip and try that to back it out It sounds like you have a mess on your hands, sorry.
Re: 340 Distributor Drive Removal [Re: Cab_Burge] #1467460
07/14/13 01:09 AM
07/14/13 01:09 AM
not the answer I wanted Cab...
I'll mess with it again some more tomorrow. Maybe I can get enough of a bite with a big screwdriver to move it backwards to help free it up. This would have been so much easier on a big block.
Re: 340 Distributor Drive Removal [Re: RangerDan440] #1467461
07/14/13 01:24 AM
07/14/13 01:24 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Lt,,, I thought you were mechanically inclined. Use an injector puller..
I am truckless..
Re: 340 Distributor Drive Removal [Re: RangerDan440] #1467462
07/14/13 01:31 AM
07/14/13 01:31 AM
Take a coat hangar & cut 2 straight lengths then bend a L at one end of each of em & see if you can hook under it & pull it up
Re: 340 Distributor Drive Removal [Re: RangerDan440] #1467463
07/14/13 09:52 AM
07/14/13 09:52 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
A fresh pair of trans pliers works nice too. May not be what they're called technically, but they expand when you squeeze them instead of close when you squeeze them. They have nice gripping teeth built in and work well for grabbing the gear.
Re: 340 Distributor Drive Removal [Re: Cab_Burge] #1467464
07/14/13 10:32 AM
07/14/13 10:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
That and if you get it up a bit take some brake clean and spray the shaft.Ive had a few that had build up on them.The brake clean will dissolve it and let the shaft come out easier.Rocky
Chrysler Firepower
Re: 340 Distributor Drive Removal [Re: therocks] #1467465
07/14/13 12:30 PM
07/14/13 12:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
And these really come in handy
Re: 340 Distributor Drive Removal [Re: RapidRobert] #1467466
07/14/13 12:38 PM
07/14/13 12:38 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Just did it this way myself a couple of weeks ago. Takes about three hands, but it can be done. Actually had to bend the wire into a bit more complex of a shape, but there is no way to explain it. I did bend it so the wire fit down between the gear teeth, otherwise there is not enough clearance through the hole.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 340 Distributor Drive Removal [Re: 471Magnum] #1467467
07/14/13 01:15 PM
07/14/13 01:15 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I have used this, and the screw driver method. Sometimes it helps to try and turn the crank backwards a tad to help remove tension/pressure from the cam gear.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 340 Distributor Drive Removal [Re: hp383] #1467468
07/14/13 01:59 PM
07/14/13 01:59 PM
I tried moving the crank backwards and a couple of different sets of long nosed pliers, its still being stubborn. I'll try cutting a coat hanger next and if that doesn't work then the intake is coming off. And its an AC car, isn't that lovely? Im tempted to call the little repair shop in town...
Re: 340 Distributor Drive Removal [Re: RangerDan440] #1467469
07/14/13 02:56 PM
07/14/13 02:56 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I use the coat hanger in a long oval shape to fish under the gear and use the top end as the handle. With a fat screwdriver rotating at the same time should wiggle it out of the bushing and oil pump.
Re: 340 Distributor Drive Removal [Re: Dave Watt] #1467470
07/14/13 04:08 PM
07/14/13 04:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I fished and wrapped some mechanics wire around one and yanked up on it. Worked for me. A coat hanger was too thick to work it under the gear if it hasn`t budged at all.
