Re: 340 Distributor Drive Removal
[Re: RangerDan440]
#1467462
07/14/13 01:31 AM
07/14/13 01:31 AM
RapidRobert
Take a coat hangar & cut 2 straight lengths then bend a L at one end of each of em & see if you can hook under it & pull it up
[Re: Cab_Burge]
#1467464
07/14/13 10:32 AM
07/14/13 10:32 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
That and if you get it up a bit take some brake clean and spray the shaft.Ive had a few that had build up on them.The brake clean will dissolve it and let the shaft come out easier.Rocky
Chrysler Firepower
