pick a cam #1465283
07/09/13 12:01 PM
07/09/13 12:01 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
hi , building a new short for my junk 408 top end is 1050 indy 230 cnc comp will be 13.5 h beams steel crank current roller is 254/262 050 650 lift with 1.6 on 107 l/c with 11.4 comp 1 3/4 pipes ,what cam and pipes should i go to
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: pick a cam [Re: Ian] #1465284
07/10/13 01:38 PM
07/10/13 01:38 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
no one has any thoughts on what i should go to in cam and pipes
Re: pick a cam [Re: Ian] #1465285
07/10/13 03:40 PM
07/10/13 03:40 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm not sure there is a better cam for your car?
But what is the weight
tranny gearing
rear gearing
tire size
heads and flow
and so on??
Re: pick a cam [Re: Dodgem] #1465286
07/10/13 10:01 PM
07/10/13 10:01 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
tranny gearing
rear gearing
tire size
275 radial ,4.3 gears ,1.76 first gear glide ,3550 lbs ,330@650 210 ex
heads and flow
and so on??
Re: pick a cam [Re: Ian] #1465287
07/10/13 10:22 PM
07/10/13 10:22 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
..... 270/276...... 685+ lift..... 109 in @ 105, 1 7/8 pipe to 3.5 collector.....
Re: pick a cam [Re: Ian] #1465288
07/10/13 10:22 PM
07/10/13 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What do you plan on turning for rpm... but as a guess
I would say 1 7/8 pri with 3 1/2 collector without
knowing alot of stuff of your engine
Re: pick a cam [Re: Ian] #1465289
07/11/13 12:53 AM
07/11/13 12:53 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s a baby cam duration wise...........where do the heads flow best to lift wise? I`m the "bigger is better" guy when cams are involved.
Re: pick a cam [Re: Thumperdart] #1465290
07/11/13 01:41 AM
07/11/13 01:41 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
max rpm 7200 ,converter is 4400 now asp with current combo , i spin it to 7600 on the gas now the new short should raise the stall to 4800 the heads stall at 700 ,i run twin 3 inch pipes with a x pipe , i was thinking of 1 7/8 pipes too, cam in the high 260 s low 270s range thanks
Re: pick a cam [Re: emarine01] #1465291
07/11/13 01:44 AM
07/11/13 01:44 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
looks good 690 net lift would be close
Re: pick a cam [Re: Ian] #1465292
07/11/13 01:58 AM
07/11/13 01:58 AM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
Nitrous converter but not a nitrous cam??
Re: pick a cam [Re: CRIKEY] #1465293
07/11/13 03:21 AM
07/11/13 03:21 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
not much gain with nitrous cams beem unless its a real big hit,i will most likely still hit it with a small shot of gas,i have been that way for 25 years ,how ya been you had been ill the last time i rang your work.
