Re: pick a cam
[Re: Dodgem]
#1465286
07/10/13 10:01 PM
07/10/13 10:01 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
I'm not sure there is a better cam for your car?
But what is the weight
tranny gearing
rear gearing
tire size 275 radial ,4.3 gears ,1.76 first gear glide ,3550 lbs ,330@650 210 ex heads and flow
and so on??
Re: pick a cam
[Re: Ian]
#1465288
07/10/13 10:22 PM
07/10/13 10:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What do you plan on turning for rpm... but as a guess I would say 1 7/8 pri with 3 1/2 collector without knowing alot of stuff of your engine
Re: pick a cam
[Re: emarine01]
#1465291
07/11/13 01:44 AM
07/11/13 01:44 AM
Ian
Victoria, Australia
..... 270/276...... 685+ lift..... 109 in @ 105, 1 7/8 pipe to 3.5 collector.....
looks good 690 net lift would be close
Re: pick a cam
[Re: CRIKEY]
#1465293
07/11/13 03:21 AM
07/11/13 03:21 AM
Ian
Victoria, Australia
Nitrous converter but not a nitrous cam??
not much gain with nitrous cams beem unless its a real big hit,i will most likely still hit it with a small shot of gas,i have been that way for 25 years ,how ya been you had been ill the last time i rang your work.
