Re: SB race oil pump?
[Re: TrWaters]
#1464997
07/08/13 10:43 PM
07/08/13 10:43 PM
Posts: 31,074 Oregon
AndyF
Titan.
I understand the sales pitch for Titan pumps in Chevy motors, but the Mopar pumps are already gerator designs. The Titan stuff does look cool though. Big points for that, just not sure I want to drop $1000 for a pump.
[Re: AndyF]
#1464999
07/08/13 10:55 PM
07/08/13 10:55 PM
Posts: 982 western pennsylvania
b1dartsport
That looks good. I haven't heard of those guys before.
I got one on ebag about 5yrs ago for $80 min bid. Sometimes I still see them there. Seems like worth it to me for a few extra bucks to make sure the heart of the engine is perfect. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: AndyF]
#1465003
07/09/13 12:51 PM
07/09/13 12:51 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Re-work a stock pump and your good...or use someone like Precision or schumans of you dont want to take the time. They simply do it all for you. I have used both in circle track stuff. You can get them to coat some of the parts as well, which is great in the long endurance apps. With drag stuff I just clean up the stock styles ( the quality is now horrible) and debur, clean, radius and open up and then check the operating and spring pressures on my pump tester. It will often find the over pressure stuff quickly, which is a pain to figure out after the fact!... ![](/ubbthreads/images/graemlins/thumbs.gif)
RIP Monte Smith
