SB race oil pump? #1464988
07/08/13 08:21 PM
07/08/13 08:21 PM
AndyF Offline OP
AndyF  Offline OP
Flipping thru some older books I see a bunch of interesting oil pump designs that were developed for the SB Mopar engine. Dual entry pickups, lowered pumps, swiveling pickups, deep rotor packages, etc.
But it appears that most of those items all died off over time. Did people determine that the SB engine worked just fine with a standard pump and so all the special pumps went away? Or is there a trick pump that still exists which I just don't know about?
Re: SB race oil pump? [Re: AndyF] #1464989
07/08/13 08:24 PM
07/08/13 08:24 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This has puzzled me too.
I have seen pictures of different styles , but about all I see available today is the pick up coming out of the bottom plate on the pump.
Re: SB race oil pump? [Re: AndyF] #1464990
07/08/13 08:24 PM
07/08/13 08:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
a stock pump in a well prepped SB will give you all the oil you need.
Re: SB race oil pump? [Re: Quicktree] #1464991
07/08/13 08:25 PM
07/08/13 08:25 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
no need for anything else
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: SB race oil pump? [Re: AndyF] #1464992
07/08/13 08:42 PM
07/08/13 08:42 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
The stock pump is more than sufficient.
Re: SB race oil pump? [Re: LSP] #1464993
07/08/13 09:54 PM
07/08/13 09:54 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Titan.
Re: SB race oil pump? [Re: TrWaters] #1464994
07/08/13 10:29 PM
07/08/13 10:29 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I got my pump here. These guys go the extra mile to make sure the pump is perfect. I have taken some new pumps apart that had clearance problems with the gears.
http://stores.precisionoilpumps.com/-strse-28/Blueprinted-Melling-SB-Mopar/Detail.bok
Re: SB race oil pump? [Re: b1dartsport] #1464995
07/08/13 10:33 PM
07/08/13 10:33 PM
b1dartsport Offline
b1dartsport  Offline
Re: SB race oil pump? [Re: b1dartsport] #1464996
07/08/13 10:42 PM
07/08/13 10:42 PM
AndyF Offline OP
AndyF  Offline OP
That looks good. I haven't heard of those guys before.
Re: SB race oil pump? [Re: TrWaters] #1464997
07/08/13 10:43 PM
07/08/13 10:43 PM
AndyF Offline OP
AndyF  Offline OP
Titan.
I understand the sales pitch for Titan pumps in Chevy motors, but the Mopar pumps are already gerator designs. The Titan stuff does look cool though. Big points for that, just not sure I want to drop $1000 for a pump.
Re: SB race oil pump? [Re: AndyF] #1464998
07/08/13 10:55 PM
07/08/13 10:55 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'm a big believer in blueprinted oil pumps, lots of efficiency improvements can be made porting and chamfering the as-cast passages in the pumps and (in the case of the small block mopar) the main cap.
I really like the milodon mopar pumps, they have a more efficient georotor and work really well.
WIZE
In Car:
Re: SB race oil pump? [Re: AndyF] #1464999
07/08/13 10:55 PM
07/08/13 10:55 PM
b1dartsport Offline
b1dartsport  Offline
I got one on ebag about 5yrs ago for $80 min bid. Sometimes I still see them there. Seems like worth it to me for a few extra bucks to make sure the heart of the engine is perfect.
Re: SB race oil pump? [Re: LSP] #1465000
07/09/13 12:17 AM
07/09/13 12:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agree and at Petts we`d open em up and de-burr the gears,check gear depth to top measurement and gacefully chamfer/port the flow paths.
Re: SB race oil pump? [Re: Streetwize] #1465001
07/09/13 03:58 AM
07/09/13 03:58 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
...I really like the milodon mopar pumps, they have a more efficient georotor and work really well.
I thought that improved efficiency pump gear (Ford? style) was only used on thier new Big Block pumps. For right now.
Re: SB race oil pump? [Re: autoxcuda] #1465002
07/09/13 08:13 AM
07/09/13 08:13 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I have a 340 Milodon Race pan that came with the billet pump housing and the "star" style rotor; I can only run the pan because the Rocky has no K-frame obstruction.
WIZE
In Car:
Re: SB race oil pump? [Re: AndyF] #1465003
07/09/13 12:51 PM
07/09/13 12:51 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Re-work a stock pump and your good...or use someone like Precision or schumans of you dont want to take the time. They simply do it all for you. I have used both in circle track stuff. You can get them to coat some of the parts as well, which is great in the long endurance apps. With drag stuff I just clean up the stock styles ( the quality is now horrible) and debur, clean, radius and open up and then check the operating and spring pressures on my pump tester. It will often find the over pressure stuff quickly, which is a pain to figure out after the fact!...
RIP Monte Smith
Re: SB race oil pump? [Re: b1dartsport] #1465004
07/09/13 04:22 PM
07/09/13 04:22 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I like this. Not a bad price at all if ya don't wanna mess with it. This is what I will use on my next small block build.
And they are only about 2 hours from me.
Thanks for the link.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
