reusing cometics ? #1463929
07/07/13 01:16 PM
07/07/13 01:16 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
there are some spots where the black coating has came off and the metal is showing.can this gasket be cleaned up and reused with some copper spray?
Re: reusing cometics ? [Re: bonefish] #1463930
07/07/13 01:19 PM
07/07/13 01:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep
Re: reusing cometics ? [Re: MR_P_BODY] #1463931
07/07/13 01:25 PM
07/07/13 01:25 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
does all the black coating need to be removed?
Re: reusing cometics ? [Re: bonefish] #1463932
07/07/13 01:28 PM
07/07/13 01:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used 1 set of the Cometic gaskets and re-used them
1 time.. I didnt do anything except spray the copper
coat on them... if the area you are talking about
is thin than just spray them
EDIT
I should have said I cleaned them with brake cleaner
first then sprayed them
Re: reusing cometics ? [Re: MR_P_BODY] #1463933
07/08/13 04:06 PM
07/08/13 04:06 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I reused mine with the coating coming off in spots. I drilled the rivets out wiped them down,and pulled off the little strings of loose coating. Sprayed all sides and reinstalled. 14.8-1, working fine.
Doug
Re: reusing cometics ? [Re: dvw] #1463934
07/09/13 03:00 AM
07/09/13 03:00 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've reused a set of cometics 9 times. a lot of the coating had come off but they still worked with copper coat.
Re: reusing cometics ? [Re: dvw] #1463935
07/09/13 12:52 PM
07/09/13 12:52 PM
Ohio
3404 Offline
3404  Offline
Ohio
Doug
+1 I do the exact same thing.
Re: reusing cometics ? [Re: 3404] #1463936
07/09/13 01:21 PM
07/09/13 01:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Same here. Clean them well and reuse them with copper coat.
Re: reusing cometics ? [Re: Al_Alguire] #1463937
07/09/13 03:18 PM
07/09/13 03:18 PM
Guys though it may work CopperCoat is not the best product for that application--we always use Holomar Spray on Cometics--it seals water like a bank vault. Coppercoat is for heat transfer and was best for old style metal head gaskets. Holomar spray is 10 times better sealer.
Re: reusing cometics ? [Re: ] #1463938
07/09/13 05:37 PM
07/09/13 05:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Copper Coat has been working well for us. 15+ to one compression and 4 digit horsepower and no issues..Just my experience
Re: reusing cometics ? [Re: Al_Alguire] #1463939
07/09/13 06:14 PM
07/09/13 06:14 PM
dogdays Offline
dogdays  Offline
it's spelled H-Y-L-O-M-A-R
R.
