Center of gravity for B body? #1459117
06/27/13 08:56 PM
06/27/13 08:56 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
Specifically 70 Road Runner, but most 66-70B bodies will probably be similar.
Re: Center of gravity for B body? [Re: 70runner] #1459118
06/27/13 11:55 PM
06/27/13 11:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
If you need to be accurate, you have to measure with accurate scales. But kentucky windage guesses, wet or dry, with or without driver, bb or sb, any non stock mods, rear discs, alum heads, ac, etc
Regardless I bet its close to gear shift in line with the cam
Re: Center of gravity for B body? [Re: jcc] #1459119
06/28/13 01:21 AM
06/28/13 01:21 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: Center of gravity for B body? [Re: kentj340] #1459120
06/28/13 03:49 AM
06/28/13 03:49 AM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Seems to me from loading the few 60s-70s Mopars on a trailer that I have done, the CG is usually just about in line with the front door/front fender gap. Maybe just a few inches aft from there, but pretty close. IMHO.
Bob
Re: Center of gravity for B body? [Re: it's Bob] #1459121
07/01/13 01:56 PM
07/01/13 01:56 PM
70runner Offline OP
70runner  Offline OP
Bob
Thx all. Short of doing the exact meas on scales, that's what I was thinking, near the outside rear view. Trying to figure out where to position the posts for my lift.
Re: Center of gravity for B body? [Re: 70runner] #1459122
07/01/13 09:03 PM
07/01/13 09:03 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If you go to the longacre site, they have an explanation how to check the CG and it also gives you directions on checking the CG height if you put the scales up 1' on one end. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Center of gravity for B body? [Re: astjp2] #1459123
07/01/13 10:18 PM
07/01/13 10:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think this post is like the guy who asks what time it is and we tell him how to build a watch. The OP wanted to know the balance point and we told him the 3d CoG.
Re: Center of gravity for B body? [Re: jcc] #1459124
07/02/13 02:50 PM
07/02/13 02:50 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Sit in the seat and put your thumb in your belly button. That is pretty close
Re: Center of gravity for B body? [Re: scatpacktom] #1459125
07/02/13 03:15 PM
07/02/13 03:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Car Life Magazine published front to rear weight distribution in thier feature reviews.
I had to dig around a little....
Bingo!
Car Life Feb. 1969
1969 Super Bee 383 auto road test
Tested weight= 3650 lbs
53.6/46.4 front to rear weight distribution
Options on tested car: disk brakes, column auto, bench seat, power windows, power steering, 3.91 gear package, hemi suspenion.
Next...
Car Life July 1969
1969 Super Bee 400-6 auto road test
Tested weight= 4160 lbs
54.2/45.8 front to rear weight distribution
Options on tested car: column auto. power drum, power steering, side scoops.
***There is an April 1969 Car Life that test Hemi and 440 Chargers. You should be able to find a copy of it online if you dig hard.
So those are actual tested measure numbers with the options that very tested car had.
70Runner, I think your car will be very close.
Re: Center of gravity for B body? [Re: scatpacktom] #1459126
07/03/13 08:00 PM
07/03/13 08:00 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
The '67 Chrysler FSM I have shows the CG as being pretty much where that would be. I'm assuming a Dodge/Plymouth FSM would show CG's too?
