Cam not fitting into cam bearing
#1458834
06/27/13 07:42 AM
06/27/13 07:42 AM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
My camshaft slid all the way in til it got to the cam bearing on the front of the motor. Cam and cam bearing both measure 1.98, should I try another front cam bearing or have the cam journal shaved about .005 in a lathe? I've never seen this before and I've wasted 2 rare free days from baseball trying to polish this cam journal.
Re: Cam not fitting into cam bearing
[Re: ProSport]
#1458835
06/27/13 08:44 AM
06/27/13 08:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You just need to size the bearings.. I use a old cam that has a slot cut into it on each bearing jourmal for sizing... slide it in and I spin it with my impact wrench
[Re: ProSport]
#1458837
06/27/13 09:48 AM
06/27/13 09:48 AM
MR_P_BODY
That sounds brutal lol. Won't that take the coating off the cam bearing?
Yep... The big name shops do the same thing.. if you have a mopar shop around you they might loan out their cam sizer to you
[Re: ProSport]
#1458839
06/27/13 10:06 AM
06/27/13 10:06 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
As said above me did you spin the cam around to confirm it is the front journal hanging you up?
Who installed the bearings and how was the front bearing installed , from the front or with the tool installed thru the rear?
I used to have a tool like Mr. P describes until I ruined a bunch of bearings replacing a couple of bearings after I sized them all initially with that tool.
Should you decide to make a tool that way the first thing you need to do is confirm the tool(cam) is absolutely straight.
[Re: Stanton]
#1458841
06/27/13 10:26 AM
06/27/13 10:26 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I just had the same issue but I had to take the block back to the shop for something else so i didn't mess with it at home. It appears my shop honed the cam bearings with something very fine. They almost look untouched until you look at them real close. The came fits perfect now.
68 Barracuda Formula S 340
[Re: Stanton]
#1458843
06/27/13 11:01 AM
06/27/13 11:01 AM
JohnRR
U.S.S.A.
Oh, do NOT mess with the cam !!!
polishing the cam journal is not the way to correct this.
I used a 320 grit medium density flap wheel to clean the #5 bearing so the cam would fit and it fit all the other bearings fine.
When I originally put the cam in it did the same thing, fit it till it came time to seat it fully making one think it's the front bearing that is the problem when the came is finally seating itself into all the bearings at basically the same time.
[Re: ProSport]
#1458845
06/27/13 11:44 AM
06/27/13 11:44 AM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
I'm a hack, but got my cam in my 440 rebuild to spin nicely with just a brake hone and some WD-40.
[Re: Cab_Burge]
#1458848
06/27/13 01:16 PM
06/27/13 01:16 PM
dartman366
Mt. Vernon, Ohio
Cure the problem, not the symptom! This is a short article taht describes the root cause and proper solution for camshafts not turning in factory Mopar blocks.
http://musclemotorsracing.com/muscle-mike-blog/82-the-real-reason-my-cam-wont-turn.html
Mopar miss the boat on te cam tunnel finishing to the correct size
small blocks have the same problem, had a 318 once that it happened to and the shop at the time told me to use the old cam with grooves filed into the journal and ream it to size,,I looked at the guy like he was out of his mind,I did it, it worked, but I didn't like it as it made the bearing surface rough,,the guy that does my work now fixes the problem if it occures as Mike explained and makes sure everything fit's as it is supposed to,,,,engine builders that know how to fix things right,,,,,,,priceless!
[Re: Cab_Burge]
#1458849
06/27/13 01:21 PM
06/27/13 01:21 PM
Obviously this would apply to new after market blocks as well, correct?
[Re: ]
#1458850
06/27/13 02:08 PM
06/27/13 02:08 PM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
My block was baked and heard that can add to the problem too
Really ?!?!?! After all the heat cycles its been through you think baking is gonna cause problems ???
[Re: dartman366]
#1458851
06/27/13 02:18 PM
06/27/13 02:18 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Really ?!?! So what did the factory do, specify all cam journals be ground undersize? Or did they hone the bearings? Or did they just pound in the cams and hope for the best?
I suppose this MM solution is the best if you're sending out a bare block to be done but most times we're already well beyond that stage when we're installing the cam and this solution is pretty much out of the question. There's nothing wrong with scraping or sanding a cam bearing to fit. Personally I don't like the hone idea unless you're sure material needs to be removed from the whole i.d. but in most case its usually hung up on a small area.
[Re: Jeremiah]
#1458853
06/27/13 02:39 PM
06/27/13 02:39 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I never had an issue with a small block mopar but I know several other that say its a BIG issue on small block fords.
