Page 1 of 4 1 2 3 4
Cam not fitting into cam bearing #1458834
06/27/13 07:42 AM
06/27/13 07:42 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
My camshaft slid all the way in til it got to the cam bearing on the front of the motor. Cam and cam bearing both measure 1.98, should I try another front cam bearing or have the cam journal shaved about .005 in a lathe?
I've never seen this before and I've wasted 2 rare free days from baseball trying to polish this cam journal.
Re: Cam not fitting into cam bearing [Re: ProSport] #1458835
06/27/13 08:44 AM
06/27/13 08:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You just need to size the bearings.. I use a old cam
that has a slot cut into it on each bearing
jourmal for sizing... slide it in and I spin it with
my impact wrench
Re: Cam not fitting into cam bearing [Re: MR_P_BODY] #1458836
06/27/13 09:39 AM
06/27/13 09:39 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
That sounds brutal lol. Won't that take the coating off the cam bearing?
Re: Cam not fitting into cam bearing [Re: ProSport] #1458837
06/27/13 09:48 AM
06/27/13 09:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... The big name shops do the same thing.. if you
have a mopar shop around you they might loan out their
cam sizer to you
Re: Cam not fitting into cam bearing [Re: ProSport] #1458838
06/27/13 09:50 AM
06/27/13 09:50 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Did you turn the cam around and just try the big end in there?I think you should buy an uncoated set and use just the 1 from it and if that does not help then clearance it.
Re: Cam not fitting into cam bearing [Re: ProSport] #1458839
06/27/13 10:06 AM
06/27/13 10:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As said above me did you spin the cam around to confirm it is the front journal hanging you up?
Who installed the bearings and how was the front bearing installed , from the front or with the tool installed thru the rear?
I used to have a tool like Mr. P describes until I ruined a bunch of bearings replacing a couple of bearings after I sized them all initially with that tool.
Should you decide to make a tool that way the first thing you need to do is confirm the tool(cam) is absolutely straight.
Re: Cam not fitting into cam bearing [Re: JohnRR] #1458840
06/27/13 10:20 AM
06/27/13 10:20 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
First pull the cam and flip it and test fit to see if that bearing is really the issue. If the cam fits the bearing, wobble the cam around a little just to seat the bearing. Now try installing it again. If it still won't just slide in, use a bit of pressure while turning it - you want to have it start in the bearing and leave a mark where its tight. Now pull it out, find the tight spot and scrape it down or sand with emery cloth.
Cam bearings are not terribly critical as far as their finish goes as long as they're not extremely loose or extremely tight. Remember, the cam only spins at half the engine speed and doesn't get the punishment main bearings have to take.
Oh, do NOT mess with the cam !!!
Re: Cam not fitting into cam bearing [Re: Stanton] #1458841
06/27/13 10:26 AM
06/27/13 10:26 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I just had the same issue but I had to take the block back to the shop for something else so i didn't mess with it at home. It appears my shop honed the cam bearings with something very fine. They almost look untouched until you look at them real close. The came fits perfect now.
68 Barracuda Formula S 340
Re: Cam not fitting into cam bearing [Re: ProSport] #1458842
06/27/13 10:40 AM
06/27/13 10:40 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I had a similar problem with with SP bearings. Cam got stuck real bad. Couldn't get to fit all the way in without lots of shaving. Figured I installed them wrong Pulled em out and installed a set of Durabond PDP-17 (uncoated) bearings after reading a couple other posts here. I used the same tool and method I had installed the others and cam slid right in with no clearancing whatsoever. My block was baked and heard that can add to the problem too??
Re: Cam not fitting into cam bearing [Re: Stanton] #1458843
06/27/13 11:01 AM
06/27/13 11:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
polishing the cam journal is not the way to correct this.
I used a 320 grit medium density flap wheel to clean the #5 bearing so the cam would fit and it fit all the other bearings fine.
When I originally put the cam in it did the same thing, fit it till it came time to seat it fully making one think it's the front bearing that is the problem when the came is finally seating itself into all the bearings at basically the same time.
Re: Cam not fitting into cam bearing [Re: JohnRR] #1458844
06/27/13 11:35 AM
06/27/13 11:35 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Who installed the cam bearings...that is a good place to start. If they are crooked in the bores you will have that problem. If you knock that bearing out (if you have the tool) it will have witness marks indicating it was no in the bore straight. Otherwise it's time for a hone as said above.
Re: Cam not fitting into cam bearing [Re: ProSport] #1458845
06/27/13 11:44 AM
06/27/13 11:44 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I'm a hack, but got my cam in my 440 rebuild to spin nicely with just a brake hone and some WD-40.
Re: Cam not fitting into cam bearing [Re: Dean_Kuzluzski] #1458846
06/27/13 12:22 PM
06/27/13 12:22 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Cure the problem, not the symptom! This is a short article taht describes the root cause and proper solution for camshafts not turning in factory Mopar blocks.
http://musclemotorsracing.com/muscle-mike-blog/82-the-real-reason-my-cam-wont-turn.html
Re: Cam not fitting into cam bearing [Re: MuscleMike] #1458847
06/27/13 01:00 PM
06/27/13 01:00 PM
Mopar miss the boat on te cam tunnel finishing to the correct size
Re: Cam not fitting into cam bearing [Re: Cab_Burge] #1458848
06/27/13 01:16 PM
06/27/13 01:16 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
small blocks have the same problem, had a 318 once that it happened to and the shop at the time told me to use the old cam with grooves filed into the journal and ream it to size,,I looked at the guy like he was out of his mind,I did it, it worked, but I didn't like it as it made the bearing surface rough,,the guy that does my work now fixes the problem if it occures as Mike explained and makes sure everything fit's as it is supposed to,,,,engine builders that know how to fix things right,,,,,,,priceless!
Re: Cam not fitting into cam bearing [Re: Cab_Burge] #1458849
06/27/13 01:21 PM
06/27/13 01:21 PM
Obviously this would apply to new after market blocks as well, correct?
Re: Cam not fitting into cam bearing [Re: ] #1458850
06/27/13 02:08 PM
06/27/13 02:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Really ?!?!?! After all the heat cycles its been through you think baking is gonna cause problems ???
Re: Cam not fitting into cam bearing [Re: dartman366] #1458851
06/27/13 02:18 PM
06/27/13 02:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Really ?!?! So what did the factory do, specify all cam journals be ground undersize? Or did they hone the bearings? Or did they just pound in the cams and hope for the best?
I suppose this MM solution is the best if you're sending out a bare block to be done but most times we're already well beyond that stage when we're installing the cam and this solution is pretty much out of the question. There's nothing wrong with scraping or sanding a cam bearing to fit. Personally I don't like the hone idea unless you're sure material needs to be removed from the whole i.d. but in most case its usually hung up on a small area.
Re: Cam not fitting into cam bearing [Re: MuscleMike] #1458852
06/27/13 02:30 PM
06/27/13 02:30 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Thank you, I will follow that advice on my 511's that are going together.
Re: Cam not fitting into cam bearing [Re: Jeremiah] #1458853
06/27/13 02:39 PM
06/27/13 02:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I never had an issue with a small block mopar but I know several other that say its a BIG issue on small block fords.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Page 1 of 4 1 2 3 4
