Re: Header gasket question
[Re: Mr.Yuck]
#1458509
06/26/13 03:10 PM
06/26/13 03:10 PM
Triple Threat
Renton Washington
My car is high temp silicone only. My brothers turbo car is the same way.
Gaskets are nice if you have a good head and a good flange. With my old TTI's and edelbrocks I reused the same header gaskets countless times.
My new heads no one makes a gasket for so I use the RTV.
[Re: B G Racing]
#1458510
06/26/13 03:12 PM
06/26/13 03:12 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
It's important to get the flanges as straight as possible.
Agreed...
I surfaced my Hooker's before I put 'em on...
Check 'em with a straight-edge...
I've never used silicone, but have had good luck with Ultra-Seal gaskets...
[Re: B G Racing]
#1458511
06/26/13 03:13 PM
06/26/13 03:13 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
It's important to get the flanges as straight as possible.If it keeps leaking try Permatex Ultra Copper Silicone.Put a heavy bead on the flange or head,bolt the header snug,let it sit over night to fully cure then tighten.Check and recheck the bolts after a few heat cycles.
thanks, I used the Fel-Pros w/ ultra copper on both sides. My mistake might have been not re-snugging after a few cycles. I had maybe 100 street miles and 5 runs on them before the went. How much flange do you need for a good seal? These seem to have about 1/16-3/32"
[Re: Mr.Yuck]
#1458513
06/26/13 03:28 PM
06/26/13 03:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Cut the end ports free from the center ones... it allows for growth without buckling the flanges.. the BEST gasket material is called Graffoil. its a stainless with graphite in it... hard to cut the stainless but the graphite allows the flange to slide easily... also if you have 1 hole PER cyl larger it gives it room to slide... ALL flanges need to slide so give it some room to do it(most flanges have just the 2 holes for mounting so 1 larger will let it slide.. if it has 3 holes make 2 larger... and not both end)
[Re: GomangoCuda]
#1458517
06/27/13 07:57 AM
06/27/13 07:57 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I always use mr.Gasket ultra seal gaskets. I used silicone once and never will again, messy and hard to clean up on a big block a-body. But most guys do use silicone.
[Re: GomangoCuda]
#1458519
06/27/13 06:58 PM
06/27/13 06:58 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Reflex.com
They will make custom gaskets also based off a template from you as well.
Isis mine with a crayon and large sheet of paper.
Do you mean Remflex? I use them. Expensive but work.
Yes. Not so smart phone
[Re: Mr.Yuck]
#1458520
06/27/13 11:04 PM
06/27/13 11:04 PM
MR_P_BODY
These are 2 piece so one tube on each side is seperat, the front flanges have been cut/sperated from the middle 2. I use washers and mani studs where possible.
If you have 5/16 studs or bolts make 1 of the holes per section a 3/8 hole for growth
[Re: GomangoCuda]
#1458521
06/27/13 11:44 PM
06/27/13 11:44 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I have found that 98% of my leaks have come from warped flanges or irregular surfaces that do not mate flush and flat. a zillon factory manifolds never used any gaskets. always spilit the flanges between cylinders so only one tube at a time gets tightened. that eliminates 99% of warp trouble I only use Permatex HI-Temp Red RTV Silicone Gasket good for 650 degrees and .250 gap fills Quote:
OEM specified. Formulated for hi-temp applications, or heavy-duty use (such as towing, etc.). Replaces almost any cut gasket by making reliable “formed-in-place” gaskets that resist cracking, shrinking and migrating caused by thermal cycling. Coats pre-cut gaskets to increase reliability. Temperature range -65?F to 650?F (-54°C to 343°C) intermittent; resists auto and shop fluids. - See more at: http://www.permatex.com/products/product...h.n7coVQKc.dpuf
IT IS IMPORTANT TO READ THE INSTRUCTIONS FOR PROPER SEALING.
home of the Sox and Martin Hemi Duster
[Re: MR_P_BODY]
#1458526
06/28/13 10:08 AM
06/28/13 10:08 AM
Mr.Yuck
Brookeville, Md
thems purdy Mr. P. I've never used 2" headers before, I've never had issues sealing up cheap 1 3/4" does the extra 1/4" make for a trickier seal? I never thought about it needing some expansion room.
The 2" tubes does have its problem... again on the center ports... with the larger tubes you have a bit less room between the 2 center ports which gives it less gasket/sealing area and thats where most headers tend to leak.. a thicker flange usually helps that.. even on a production manifold we allowed for expansion (if you look at the holes).. also what Fred posted and the production manifolds not running gaskets.. yes thats true BUT a manifold is a TOTALLY different design than a header flange.. the manifold has thickness to keep it from warping unlike a 5/16 flange(which most headers have).. I use 3/8 flanges to reduce the warping along with the larger hole set up... also most headers have the weld bead on the gasket surface which is a plus and a negative ..its a small area that bites into the gasket to seal BUT it also cuts as it grows and contracts EDIT You have to figure in expansion on the exhaust... a standard size car with full exhaust and normal temp will have 3/4"+ growth at the tip of the tail pipe
I wonder if I welded extra "meat" between the center tubes and sanded them flat if that would help?
