Header gasket question #1458507
06/26/13 02:58 PM
06/26/13 02:58 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I seem to have blown out at least one side header gasket. These are hooker super comps 2" primaries on Stage VI heads. I have never had issues w/ header gaskets in the past, I've used mainly Fel-Pro 1414's and Mr. Gaskets. I was talking to a buddy about it and he says why run a gasket. We all run high temp silicone and that's it. (circle track cars) Says he has never had any problems, Said to use a ample amount and let it set 2-3 days before running the engine. Says it almost melts and sets in any crack you might have. any ideas? I know at least the drovers side is leaking so I'll pull that off and take a look. These are used headers som maybe I should re-weld the ports/flanges and grind them smooth. what do you guys use?
Coming soon!!!!
Re: Header gasket question [Re: Mr.Yuck] #1458508
06/26/13 03:06 PM
06/26/13 03:06 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It's important to get the flanges as straight as possible.If it keeps leaking try Permatex Ultra Copper Silicone.Put a heavy bead on the flange or head,bolt the header snug,let it sit over night to fully cure then tighten.Check and recheck the bolts after a few heat cycles.
Re: Header gasket question [Re: Mr.Yuck] #1458509
06/26/13 03:10 PM
06/26/13 03:10 PM
Renton Washington
Triple Threat Offline
Renton Washington
My car is high temp silicone only. My brothers turbo car is the same way.
Gaskets are nice if you have a good head and a good flange. With my old TTI's and edelbrocks I reused the same header gaskets countless times.
My new heads no one makes a gasket for so I use the RTV.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Header gasket question [Re: B G Racing] #1458510
06/26/13 03:12 PM
06/26/13 03:12 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Agreed...
I surfaced my Hooker's before I put 'em on...
Check 'em with a straight-edge...
I've never used silicone, but have had good luck with Ultra-Seal gaskets...
Re: Header gasket question [Re: B G Racing] #1458511
06/26/13 03:13 PM
06/26/13 03:13 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
thanks, I used the Fel-Pros w/ ultra copper on both sides. My mistake might have been not re-snugging after a few cycles. I had maybe 100 street miles and 5 runs on them before the went. How much flange do you need for a good seal? These seem to have about 1/16-3/32"
Re: Header gasket question [Re: Mr.Yuck] #1458512
06/26/13 03:25 PM
06/26/13 03:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The silicone should seal any low areas.It's best to have as much clamp area as well as straight flanges.You may want to add a nice weld bead around each port then sand them flat on a belt sander.If you have a spare head bolt it on and see if the flange is warped or bent.If you have seperate tubes use washers on the bolts that are in the parting line.
Re: Header gasket question [Re: Mr.Yuck] #1458513
06/26/13 03:28 PM
06/26/13 03:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cut the end ports free from the center ones... it allows
for growth without buckling the flanges.. the BEST
gasket material is called Graffoil. its a stainless
with graphite in it... hard to cut the stainless but
the graphite allows the flange to slide easily... also
if you have 1 hole PER cyl larger it gives it room
to slide... ALL flanges need to slide so give it some
room to do it(most flanges have just the 2 holes for
mounting so 1 larger will let it slide.. if it has 3
holes make 2 larger... and not both end)
Re: Header gasket question [Re: MR_P_BODY] #1458514
06/26/13 03:53 PM
06/26/13 03:53 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
These are 2 piece so one tube on each side is seperat, the front flanges have been cut/sperated from the middle 2. I use washers and mani studs where possible.
Re: Header gasket question [Re: Mr.Yuck] #1458515
06/27/13 05:33 AM
06/27/13 05:33 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Reflex.com
They will make custom gaskets also based off a template from you as well.
Isis mine with a crayon and large sheet of paper.
Re: Header gasket question [Re: DJVCuda] #1458516
06/27/13 07:44 AM
06/27/13 07:44 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Reflex.com
Do you mean Remflex? I use them. Expensive but work.
Re: Header gasket question [Re: GomangoCuda] #1458517
06/27/13 07:57 AM
06/27/13 07:57 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I always use mr.Gasket ultra seal gaskets. I used silicone once and never will again, messy and hard to clean up on a big block a-body. But most guys do use silicone.
Re: Header gasket question [Re: GomangoCuda] #1458518
06/27/13 02:34 PM
06/27/13 02:34 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Reflex.com
x3 for Remflex
"These go to eleven", Nigel Tufnel
Re: Header gasket question [Re: GomangoCuda] #1458519
06/27/13 06:58 PM
06/27/13 06:58 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Reflex.com
Yes. Not so smart phone
Re: Header gasket question [Re: Mr.Yuck] #1458520
06/27/13 11:04 PM
06/27/13 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have 5/16 studs or bolts make 1 of the holes
per section a 3/8 hole for growth
Re: Header gasket question [Re: GomangoCuda] #1458521
06/27/13 11:44 PM
06/27/13 11:44 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I have found that 98% of my leaks have come from warped flanges or irregular surfaces that do not mate flush and flat. a zillon factory manifolds never used any gaskets.
always spilit the flanges between cylinders so only one tube at a time gets tightened. that eliminates 99% of warp trouble
I only use
Permatex HI-Temp Red RTV Silicone Gasket
good for 650 degrees and .250 gap fills
OEM specified. Formulated for hi-temp applications, or heavy-duty use (such as towing, etc.). Replaces almost any cut gasket by making reliable “formed-in-place” gaskets that resist cracking, shrinking and migrating caused by thermal cycling. Coats pre-cut gaskets to increase reliability. Temperature range -65?F to 650?F (-54°C to 343°C) intermittent; resists auto and shop fluids. - See more at: http://www.permatex.com/products/product...h.n7coVQKc.dpuf
IT IS IMPORTANT TO READ THE INSTRUCTIONS FOR PROPER SEALING.
home of the
Sox and Martin Hemi Duster
Re: Header gasket question [Re: HEMIFRED] #1458522
06/28/13 09:09 AM
06/28/13 09:09 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Mr. P I think the only larger hole now is for #1 and #2. I'll open the others up.
Fred, is the red better than the copper? The copper has a higher heat range. And do you use w/ or w/o gasket?
As mentioned flanges between 1-3, 2-4 are cut... It appears the leak is between 3-5.
Re: Header gasket question [Re: Mr.Yuck] #1458523
06/28/13 09:18 AM
06/28/13 09:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah if you have 1 bolt hole the proper size, that
keeps the pipe located right and the larger hole will
allow the growth .. the center ports are the ones
that tend to leak.. 2 bolts holding 2 pipes with double
the heat
EDIT
I like the bolting set up on my W-9 heads.. it has
3 bolts for the center 2 ports BUT it wiuld be better
if it had 1 more bolt at the center bottom(4 bolts total
on the center ports)
Re: Header gasket question [Re: MR_P_BODY] #1458524
06/28/13 09:30 AM
06/28/13 09:30 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
thems purdy Mr. P.
I've never used 2" headers before, I've never had issues sealing up cheap 1 3/4" does the extra 1/4" make for a trickier seal? I never thought about it needing some expansion room.
Re: Header gasket question [Re: Mr.Yuck] #1458525
06/28/13 10:03 AM
06/28/13 10:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
thems purdy Mr. P.
The 2" tubes does have its problem... again on the
center ports... with the larger tubes you have a bit
less room between the 2 center ports which gives it
less gasket/sealing area and thats where most headers
tend to leak.. a thicker flange usually helps that..
even on a production manifold we allowed for expansion
(if you look at the holes).. also what Fred posted
and the production manifolds not running gaskets..
yes thats true BUT a manifold is a TOTALLY different
design than a header flange.. the manifold has thickness
to keep it from warping unlike a 5/16 flange(which
most headers have).. I use 3/8 flanges to reduce the
warping along with the larger hole set up... also
most headers have the weld bead on the gasket surface
which is a plus and a negative ..its a small area
that bites into the gasket to seal BUT it also cuts
as it grows and contracts
EDIT
You have to figure in expansion on the exhaust... a
standard size car with full exhaust and normal temp
will have 3/4"+ growth at the tip of the tail pipe
Re: Header gasket question [Re: MR_P_BODY] #1458526
06/28/13 10:08 AM
06/28/13 10:08 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
thems purdy Mr. P.
EDIT
I wonder if I welded extra "meat" between the center tubes and sanded them flat if that would help?
