Re: Fuel flow thru reg?
[Re: Clanton]
#1453761
06/16/13 03:57 PM
06/16/13 03:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Wont the line to the carbs be the restriction also?
Actually the needle and seat(.110 is stock in most ) is the restriction point)
[Re: bigtimeauto]
#1453764
06/16/13 07:09 PM
06/16/13 07:09 PM
Posts: 3,695 nc
emarine01
nc
From the testing we did, BG 280 @ 13.5v thru a Holley 12-803 reg set @ 7 psi it took 28 sec to flow 1 gal, Same set up but with BG reg set @ 7 psi took 19 sec to fill 1 gal, Tested the pump pressure @ 18 psi dead headed, The problem which is new from the last 2 runs is the truck is launching better, 1.39 & 1.35 from 1.65 ave but after the 60ft mark it falls on its face dropping from 6900 to 4500 then hunts up and down to 5500, This was with the Holley reg, We run .120 needles on either a bg 850 annular or a bg 1000 race demon and the annular was the 1.35 60ft, both carbs ran out of fuel @ the 60ft mark, I have swapped out regs to the BG but have no way to test till next week end @ the track , I am not sure if it is a G force problem or a reg volume problem from the difference in faster 60ft times, All opinions welcome, Thankx Craig
[Re: skrews]
#1453766
06/16/13 10:11 PM
06/16/13 10:11 PM
Posts: 3,695 nc
emarine01
nc
You running jet extensions in the rear ? And no rear power valve ? You knew somebody was going to ask .
Yes & yes, From the best I could tell we were nosing over @ the 175ft mark all season and the rpm would not go much past 7k before this problem started, most likely the small reg, The truck never launched well but made it up mid track, now we are leaving hard and falling flat, The crazy thing is as bad as we are now running we only lost 2 to 3 tenths, it seems that the launch carries the truck all the way thru 200ft.
[Re: skrews]
#1453767
06/16/13 10:12 PM
06/16/13 10:12 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
you running a cut open hose from bowl vent to bowl vent? What you are describing is a rich stumble not lean.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: emarine01]
#1453769
06/16/13 10:23 PM
06/16/13 10:23 PM
bigtimeauto
Trophy Winner
Trophy Winner
No hose on the vent tubes, I will get on it the tubes are kinda short, That never crossed my mind, Thankx
and make sure your floats are set with the car running!
here is a pick of the hose, cut about 1" open:
[Re: emarine01]
#1453776
06/16/13 11:01 PM
06/16/13 11:01 PM
Thumperdart
State of confusion
Mine doesn`t move but maybe a 1/4 lb if that from idle through 7000.........Magnafuel 300 pump and their 2-port reg. Before blameing the reg have you checked for restrictions before the pump? Pre-filter, bends etc.
