Page 1 of 3 1 2 3
Fuel flow thru reg? #1453757
06/16/13 11:41 AM
06/16/13 11:41 AM
nc
E
emarine01 Offline OP
E
nc
How much fuel can you flow thru a Holley 12-803 chrome reg @ 7psi in one min with 18 psi input pressure? Or whats the fastest time anyone has tested in seconds to fill a gallon?
Re: Fuel flow thru reg? [Re: emarine01] #1453758
06/16/13 12:28 PM
06/16/13 12:28 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Wont the line to the carbs be the restriction also?
Re: Fuel flow thru reg? [Re: emarine01] #1453759
06/16/13 12:32 PM
06/16/13 12:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Check out the old Pro-Stock cars and those regs looked like stock Holleys at least from the outside. I`ve seen em on real fast cars recently also..........Try it and post your results....
Re: Fuel flow thru reg? [Re: emarine01] #1453760
06/16/13 01:48 PM
06/16/13 01:48 PM
Washington
skrews Offline
skrews  Offline
Washington
Years ago my friend and I tested this. The car had a BG 280 pump, and with the Holley reg it took 40 something sec. With the Holley Big Port reg it took 15ish IIRC. Unreal ! I would never use one of those little Holley regs again. Plenty of people go fast on them, but that don't mean its optimal.
Re: Fuel flow thru reg? [Re: Clanton] #1453761
06/16/13 03:57 PM
06/16/13 03:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually the needle and seat(.110 is stock in most )
is the restriction point)
Re: Fuel flow thru reg? [Re: MR_P_BODY] #1453762
06/16/13 04:42 PM
06/16/13 04:42 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i gota buddy runs very low 8,s with a holley big port reg,very inexpensive and basic.
Re: Fuel flow thru reg? [Re: emarine01] #1453763
06/16/13 05:55 PM
06/16/13 05:55 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Its not about how much one can flow in a minute its about whether or not it can refill YOUR bowls versus how much fuel your car is using. A car with 2 4bbls (4 bowls) obviously holds more fuel than a single carb with only 2 bowls. so its easier to keep filled. You only need to flow enough to keep your bowls filled.The size of your needle and seats also is a factor in restriction.
Fuel pumps need to be strong if they are mounted in the rear to overcome G forces of the car leaving with the gallon or so of fuel in the line.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453764
06/16/13 07:09 PM
06/16/13 07:09 PM
nc
E
E
nc
From the testing we did, BG 280 @ 13.5v thru a Holley 12-803 reg set @ 7 psi it took 28 sec to flow 1 gal, Same set up but with BG reg set @ 7 psi took 19 sec to fill 1 gal, Tested the pump pressure @ 18 psi dead headed, The problem which is new from the last 2 runs is the truck is launching better, 1.39 & 1.35 from 1.65 ave but after the 60ft mark it falls on its face dropping from 6900 to 4500 then hunts up and down to 5500, This was with the Holley reg, We run .120 needles on either a bg 850 annular or a bg 1000 race demon and the annular was the 1.35 60ft, both carbs ran out of fuel @ the 60ft mark, I have swapped out regs to the BG but have no way to test till next week end @ the track , I am not sure if it is a G force problem or a reg volume problem from the difference in faster 60ft times, All opinions welcome, Thankx Craig
Re: Fuel flow thru reg? [Re: emarine01] #1453765
06/16/13 09:23 PM
06/16/13 09:23 PM
Washington
skrews Offline
skrews  Offline
Washington
You running jet extensions in the rear ? And no rear power valve ? You knew somebody was going to ask .
Re: Fuel flow thru reg? [Re: skrews] #1453766
06/16/13 10:11 PM
06/16/13 10:11 PM
nc
E
E
nc
Yes & yes, From the best I could tell we were nosing over @ the 175ft mark all season and the rpm would not go much past 7k before this problem started, most likely the small reg, The truck never launched well but made it up mid track, now we are leaving hard and falling flat, The crazy thing is as bad as we are now running we only lost 2 to 3 tenths, it seems that the launch carries the truck all the way thru 200ft.
Re: Fuel flow thru reg? [Re: skrews] #1453767
06/16/13 10:12 PM
06/16/13 10:12 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you running a cut open hose from bowl vent to bowl vent? What you are describing is a rich stumble not lean.
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453768
06/16/13 10:17 PM
06/16/13 10:17 PM
nc
E
E
nc
No hose on the vent tubes, I will get on it the tubes are kinda short, That never crossed my mind, Thankx
Re: Fuel flow thru reg? [Re: emarine01] #1453769
06/16/13 10:23 PM
06/16/13 10:23 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
and make sure your floats are set with the car running!
here is a pick of the hose, cut about 1" open:
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453770
06/16/13 10:30 PM
06/16/13 10:30 PM
nc
E
E
nc
We set the floats @ idle just past half way up the sight glass, Are you feeding that holley from both sides? If yes why?
Re: Fuel flow thru reg? [Re: emarine01] #1453771
06/16/13 10:32 PM
06/16/13 10:32 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
No just the one side. Its cleaner to feed it from the drivers side, i hate short stumpy lines:
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453772
06/16/13 10:42 PM
06/16/13 10:42 PM
nc
E
E
nc
How steady should a fuel pressure gauge be? I have 7 psi @ idle and if I hold the rpm up high say 6k for 10 secs the pressure will drop to 5.5 and the primary fuel bowl will drop from a bit over half the sight glas to the bottom of the glass?
Re: Fuel flow thru reg? [Re: emarine01] #1453773
06/16/13 10:46 PM
06/16/13 10:46 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
You should be able to maintain the bowl if the car is not under load.
Re: Fuel flow thru reg? [Re: bigtimeauto] #1453774
06/16/13 10:54 PM
06/16/13 10:54 PM
nc
E
E
nc
It doesn't take much pedal to hit 6k no load, Dont know what the level drops to under load, I was supprised to see the level drop no load, is that normal?
Re: Fuel flow thru reg? [Re: emarine01] #1453775
06/16/13 10:55 PM
06/16/13 10:55 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
no its not, sounds like you need a new pump
Re: Fuel flow thru reg? [Re: emarine01] #1453776
06/16/13 11:01 PM
06/16/13 11:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine doesn`t move but maybe a 1/4 lb if that from idle through 7000.........Magnafuel 300 pump and their 2-port reg. Before blameing the reg have you checked for restrictions before the pump? Pre-filter, bends etc.
Page 1 of 3 1 2 3
