Front Sway Bar Detailed Drawing wanted #1452782
06/14/13 04:18 AM
06/14/13 04:18 AM
Germany
1964Polara Offline OP
Germany
I want to let fabricate an HD Front Anti Sway for my 1979 D150.
Bushings etc. will I use universal stuff/make my own...wanna go ~1.5 inch diameter
I would need a detailed drawing with measures.
Any idea how to get?
Re: Front Sway Bar Detailed Drawing wanted [Re: 1964Polara] #1452783
06/16/13 03:43 PM
06/16/13 03:43 PM
scratchnfotraction Offline
I have a complete swaybar set op on the bench,i can post pics if you want.
then you can tell me where to pull the measurments from end to end.
let me know if that would help out.
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452784
06/16/13 03:53 PM
06/16/13 03:53 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
i like his idea.
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452785
06/16/13 04:08 PM
06/16/13 04:08 PM
Germany
Germany
You make my Day........
Straight wide/length in the middle, each Arm length and angle would be Great
Plus some photos...
Many Thanx in advance
Re: Front Sway Bar Detailed Drawing wanted [Re: 1964Polara] #1452786
06/16/13 05:27 PM
06/16/13 05:27 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
The front sway bars I've seen attach to the strut rods. I've read that some of the very early 1970's sway bars attached directly to the control arm. (Not sure if this is correct?) I've never seen one attached directly to the control arm.
If a guy want's to run a 1.5" sway bar, it would probably be best to attach it directly to the control arm. Such a large sway bar pulling on the much smaller strut rods would probably cause the strut rods to flex and possibly bend.
The vans used the same or similar control arms as the trucks and attached the sway bar directly to the control arm. It may be possible to modify the van's sway bar mounting and make it work on a truck.
Re: Front Sway Bar Detailed Drawing wanted [Re: 1964Polara] #1452787
06/16/13 08:50 PM
06/16/13 08:50 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Factory bar is about 24 mm, that will be a major increase ...
I was eyeballing some other set ups at the u pull, some Ford vans have a pretty good size bar, and was looking at the way they (and GM trucks) attach to the lower arm, but at present the truck needs other stuff sooner ...
It takes gasoline to interest me.
Re: Front Sway Bar Detailed Drawing wanted [Re: QuickDodge] #1452788
06/16/13 10:49 PM
06/16/13 10:49 PM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
My 72, I put on a 72 only sway bar. It bolts to the control arm under the bump stop. Yes the bump stop is different from a non sway bar truck.
The factory sway bar is more than adequate. It was a HUGE improvement to my truck.
Re: Front Sway Bar Detailed Drawing wanted [Re: 1964Polara] #1452789
06/17/13 08:03 AM
06/17/13 08:03 AM
Plus some photos...
the big bar with splines on the end with alum arms like used on sprint cars/race cars/monster trucks could fit the bill here also.
basic square shape, 2 mounts at the frame, 2 alum arms(vary in length) attaches to the LCA or with end links,can even add pre-load to the chassis with them.
very light weight,large spring rates,very simple to adapt to any chassis.
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452790
06/18/13 11:39 PM
06/18/13 11:39 PM
here is a couple pics of a 1/2 ton D-150 swaybar.
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452791
06/18/13 11:40 PM
06/18/13 11:40 PM
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452792
06/18/13 11:41 PM
06/18/13 11:41 PM
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452793
06/18/13 11:41 PM
06/18/13 11:41 PM
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452794
06/18/13 11:42 PM
06/18/13 11:42 PM
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452795
06/19/13 12:03 AM
06/19/13 12:03 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
I got one from a 92-93 D250, pretty much looks just the same except the links for the strut rod are made different than yours.
On mine the same bushing will work in both locations.
Did a little searching and found Moog problem solver bushings, poly instead of rubber, will interchange, and are much cheaper ...
I got two sets of K3170, IIRC they were $8.20 each set. Shipped, ebay.
K3170 is two bushings. lots cheaper than the pretty red ones, these are blue.
That is 24 mm, other sizes may be K3171, 3172, etc, not sure.
AC/Delco cross references them, are black, and also poly, but I get the idea perhaps softer? I can' tell.
Local parts house had the AC Delco, so got them to try.
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452796
06/19/13 04:38 AM
06/19/13 04:38 AM
Germany
Germany
Many thanx scratchin!!!!
It seems they attach the Sway bar to the Strut rods?
I got the truck lowered so I got anyhow the Van LCA's.
Don't they have holes to mount the Sway Bar direct to the LCA with/without Sway Bar End links?
I like the idea more to attach the sway bar to the LCA's....
What do you guys think?
Re: Front Sway Bar Detailed Drawing wanted [Re: 1964Polara] #1452797
06/19/13 09:09 AM
06/19/13 09:09 AM
72 truck was the only yr to have the bar bolt to the LCA.
all other dodge truck I have seen with a bar hook to the strut rods.
I have a set of the wider pocketed LCAs from a 1 ton truck, the sway bar for it is a little thicker and bent a little more on the ends to relocate the end links to hook to strut rods.(the 1/2 bar hits LCA but it could be nothed/braced to allow it to fit without hitting.)
IMHO,works just as goodhooke to strut rod, it sure firmed up the front of my truck..but I added the steering box frame support bracket at the same time.
340 shorty swaped a rear sway bar from a r/t dakota that bolt right onto the D model truck.
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452798
07/08/13 11:04 PM
07/08/13 11:04 PM
here are some pics of a sprint car/monster truck swaybar set up.
big splined bar with splined clamp on arms. just need end links to fit.
these are some LOONNGGG end links on this truck but it works rather well and the big KING shocks give a soft ride. the sway bar does a good job controling the body roll while in action.
hope these pics give you a better idea of what I was talking about.
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452799
07/08/13 11:07 PM
07/08/13 11:07 PM
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452800
07/08/13 11:08 PM
07/08/13 11:08 PM
Re: Front Sway Bar Detailed Drawing wanted [Re: scratchnfotraction] #1452801
07/08/13 11:08 PM
07/08/13 11:08 PM
