Any luck racing with surpentine belts? #1450414
06/10/13 01:07 AM
06/10/13 01:07 AM
south central,Pa
mopar_to_ya Offline OP
south central,Pa
I have a set-up from March pulleys, but haven't used it as a few guys around here don't like the surpentine style belt.
What's your thoughts? btw, these are bowtie buddies, so I don't put much faith in what they say,lol.
It's a bigblock with a torque flight!!!
Re: Any luck racing with surpentine belts? [Re: mopar_to_ya] #1450415
06/10/13 01:13 AM
06/10/13 01:13 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've road-raced a car with a serpentine belt - to 6000 & back repeatedly for hours - no problem. It's the car's stock setup. As long as your pulleys are aligned properly and the tensioner is good, I don't see a problem.
Re: Any luck racing with surpentine belts? [Re: topside] #1450416
06/10/13 01:26 AM
06/10/13 01:26 AM
south central,Pa
south central,Pa
this set-up doesn't use a tensioner. At least I didn't get one with it. It uses the stock type brackets and slider adjustment.
thanks
Re: Any luck racing with surpentine belts? [Re: mopar_to_ya] #1450417
06/10/13 10:28 AM
06/10/13 10:28 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
My ride came with a serpentine setup.... but no problems here.
It sees 6,500-6,800 every pass and thousands of miles on the street.
The only time it ever had issues was when trying to overdrive a supercharger with the same serpentine belt. No supercharger. No problems.
Re: Any luck racing with surpentine belts? [Re: mopar_to_ya] #1450418
06/10/13 10:36 AM
06/10/13 10:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a reason the factory went to it... it has
more surface area to the pulley... if you have the
stuff in line it will last for years with less tension...
still need to have enough tension but you dont need
your long lever bar to tighten it up
Re: Any luck racing with surpentine belts? [Re: MR_P_BODY] #1450419
06/10/13 10:53 AM
06/10/13 10:53 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've been running a serpentine belt for a while. Only on the crank to alternator, no issues here
Re: Any luck racing with surpentine belts? [Re: roadhazard] #1450420
06/10/13 11:56 AM
06/10/13 11:56 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
our serpentine kits run to 7500 rpm with zero problems but its got a tensioner designed into the kit.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Any luck racing with surpentine belts? [Re: Jerry] #1450421
06/10/13 06:47 PM
06/10/13 06:47 PM
dogdays Offline
dogdays  Offline
My SHO motor runs serpentine belts to 7500 rpm through the gears.
R.
Re: Any luck racing with surpentine belts? [Re: dogdays] #1450422
06/10/13 06:51 PM
06/10/13 06:51 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
... to serp belt set-ups
Re: Any luck racing with surpentine belts? [Re: dOc !] #1450423
06/11/13 12:07 AM
06/11/13 12:07 AM
south central,Pa
south central,Pa
Thanks guys for the input.
I'll give er a shot. I already have it so why not, lol.
Re: Any luck racing with surpentine belts? [Re: dOc !] #1450424
06/11/13 12:08 AM
06/11/13 12:08 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Serp belts are great, just very critical for belt alignment and tension. Auto tensioners are really best but even some OEs didn't use them. If you go that route, buy a strain gauge to set the tension correctly.
Re: Any luck racing with surpentine belts? [Re: Skeptic] #1450425
06/11/13 12:24 AM
06/11/13 12:24 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
...but WITH a tensioner in the combo it is a muchO better package ... the bearings, bushings and belts last much longer
