Any luck racing with surpentine belts?
#1450414
06/10/13 01:07 AM
06/10/13 01:07 AM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
I have a set-up from March pulleys, but haven't used it as a few guys around here don't like the surpentine style belt. What's your thoughts? btw, these are bowtie buddies, so I don't put much faith in what they say,lol.
It's a bigblock with a torque flight!!!
Re: Any luck racing with surpentine belts?
[Re: topside]
#1450416
06/10/13 01:26 AM
06/10/13 01:26 AM
mopar_to_ya
south central,Pa
this set-up doesn't use a tensioner. At least I didn't get one with it. It uses the stock type brackets and slider adjustment. thanks
[Re: mopar_to_ya]
#1450418
06/10/13 10:36 AM
06/10/13 10:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
There is a reason the factory went to it... it has more surface area to the pulley... if you have the stuff in line it will last for years with less tension... still need to have enough tension but you dont need your long lever bar to tighten it up
