Re: P-V clearance with MP 590?
[Re: 11secondC]
#1444713
05/30/13 12:05 PM
05/30/13 12:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put a test spring on the intake and the exhaust and test your own set up... use a dial indicator and at full lift push down on the rocker and measure the distance
[Re: 11secondC]
#1444715
05/30/13 01:10 PM
05/30/13 01:10 PM
MR_P_BODY
Uh, thanks for nothing? I wouldn't have asked the question if I had the tools to do so...
Do what you want..... last time I try to help you.. plus you better tell them what ratio rockers
[Re: 11secondC]
#1444716
05/30/13 01:21 PM
05/30/13 01:21 PM
Posts: 1,505 TN
SCATPACK 1
TN
Wow what a jerk of response! I doubt you will get any info or a response from anyone else on this board. Mike is very well thought of by everyone on here.
Old Geezer Racing
[Re: 11secondC]
#1444717
05/30/13 02:15 PM
05/30/13 02:15 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Maybe you should borrow the tools to do so , unless someone has your exact combination with everything machined exactly the same it's a guess at best and I would NOT trust a guess .
How was that for less than nothing ?
[Re: SCATPACK 1]
#1444718
05/30/13 02:16 PM
05/30/13 02:16 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
X2
[Re: 11secondC]
#1444723
05/30/13 02:30 PM
05/30/13 02:30 PM
Posts: 1,162 s e mich
ro23car
s e mich
thats a crappy resopnce on your part.different engines have different variables.
[Re: 11secondC]
#1444724
05/30/13 02:42 PM
05/30/13 02:42 PM
JohnRR
U.S.S.A.
Zero deck 440 with SRP's flat-tops -6cc valve reliefs...MP 590, 75 cc Edelbrocks, Marine Fel-pro's...
Anyone run into issues with the cam in @ 102-104?
are you running this cam now ? if so what is it in at and what is your current piston to valve clearance?
The only cliques are those that people create for themselves.
[Re: JohnRR]
#1444727
05/30/13 03:04 PM
05/30/13 03:04 PM
Posts: 577 Grand Rapids, MI
11secondC
Grand Rapids, MI
John...I've seen similar questions by different posters that have been asked on this board before, not necessarily mine fwiw...and it's amazing the difference in responses given depending on who posted the question. Is what it is.
I completely understand the "correct" way, is to measure it and again I understand the catastrophic consequences if I get it wrong.
Currently running the MP557...no idea on where I'm at, again don't have the tools to check it. Been running now 2 years...a friend has offered a nib 590 he's never ran, thought maybe I would give it a shot. Cam has been around what 30+ years, and I'm guessing someone at one time has tried running it in a zero deck motor, if it worked with a old TRW 6 pak piston, I would think it should be ok with mine...might be I'm wrong, don't know.
I've actually met Mike in the pits a few years back, seemed like a nice enough guy...my apologies to him for being so curt...
[Re: VernMotor]
#1444728
05/30/13 03:09 PM
05/30/13 03:09 PM
11secondC
Grand Rapids, MI
Well I have very close to the same combo..But not sure I want to tell you anything !!....gezz man chill out.. Now I have a lot of valve to piston clearnce.. same cam- flat top pistons. 0 deck- stock crank-stock length rods- 1.5 rockers. over .150 on both intake and exhaust . But you really should not take anyone word on this.. bad things can and will happen if it is not right..I would have to look and see what size my relieves are.cam is in at 101. heads are 72cc.
Thanks, I appreciate it.
[Re: 11secondC]
#1444729
05/30/13 03:11 PM
05/30/13 03:11 PM
MR_P_BODY
The clique's on here are funny.
About what I expected, understandable since my screenname isn't bbodybob or abodyjoe...
Hey smart a$$ your the one asking for answers... instead of your snide remark you could have just said I dont have the equipment to do it right... there isnt any clique on here and we would have been more than happy to try and help you ... MAYBE Jamie (Vernmotors) can give you a ball park number that you'll be happy with
[Re: MR_P_BODY]
#1444730
05/30/13 04:39 PM
05/30/13 04:39 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I'm not as knowledgable as Mike or some of the others on here but i used to run a .670 roller 280 at .050 dur with 6 pack pistons, 76 cc RPM's snd steel shim head gaskets and they cleared fine. I run the .590 with the same heads now but with dome pistons and felpros. I clayed the pistons on both. BTW, love your 66 Fury, you see very few 65-6 at the strip. I used to have a 66 Fury 111 with a 383. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 11secondC]
#1444731
05/30/13 06:40 PM
05/30/13 06:40 PM
Posts: 427 saint paul mn.
johnzgarage
saint paul mn.
O.k. thats a SIMPLE QUESTION !!!!.....no. I have clayed out a flat top ross, zero deck , 63 cc stage6 head @ 104 1.5 rocker. Found no problems.
