installed centerline for .557 mopar cam? #1440001
05/21/13 04:58 PM
05/21/13 04:58 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Getting ready to put the 440 back together and just trying to search out the best centerline to install this thing at.
Re: installed centerline for .557 mopar cam? [Re: rck850] #1440002
05/21/13 05:28 PM
05/21/13 05:28 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Those cams are on a 110 lsa,Mopar recommended them in at 108. A lot of guys advance MP cams further than the 2 degrees Mopar recommended . It really depends on the rest of the combination,heavy cars tend to like them advanced.
Keith
Re: installed centerline for .557 mopar cam? [Re: Dunnuck Racing] #1440003
05/21/13 07:13 PM
05/21/13 07:13 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
I have a Comp Cams magnum series timing set it allows 4* advance and 4* retarded is there any way to get only 2* out of it so I can just install it at Mopar's recommended centerline? It's a pretty mild combo 10.5cr with eddy heads, 3.72 gear and 3000 converter. all in a 3200lb duster.
Re: installed centerline for .557 mopar cam? [Re: rck850] #1440004
05/21/13 07:23 PM
05/21/13 07:23 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Seen those installed in the 104 range too.
Pick a spot and go. Want more low end, especially with lower compression, put it in more than 2* advanced.
Re: installed centerline for .557 mopar cam? [Re: rck850] #1440005
05/21/13 07:51 PM
05/21/13 07:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put it in at the 4* advanced BUT I would advise you
to degree the cam... its too easy for the factory OR
you to be off.. by degreeing it you KNOW where it is...
if you dont have the equipment or dont know how then
ask a buddy or take it to a shop.. they shouldnt
charge you much
Re: installed centerline for .557 mopar cam? [Re: MR_P_BODY] #1440006
05/21/13 08:31 PM
05/21/13 08:31 PM
ill
dennismopar73 Offline
ill
110 c/l cam I never like to go under a 105-106 install c/l, that's me .
I would have rather bought a cam that was at 105 c/l , then put that one in at @ 102 c/l! That's just me thing,
Re: installed centerline for .557 mopar cam? [Re: MR_P_BODY] #1440007
05/21/13 09:30 PM
05/21/13 09:30 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree with Mr. P.
Just because you put the timing chain set at +4 doesn't mean the cam is anywhere near that. And combo is important. But a typical combo suitable for that cam likes the -installed intake centerline 104-106 ATC.
If the combo likes less than that, it is the wrong cam.
Re: installed centerline for .557 mopar cam? [Re: dennismopar73] #1440008
05/21/13 10:10 PM
05/21/13 10:10 PM
Northern Indiana
Northern Indiana
So you would rather the cam company cuts the keyway with more advance rather than use an offset cam key? Basically your doing the same thing. Unless you are confusing lsa with icl.
Keith
Re: installed centerline for .557 mopar cam? [Re: 440Jim] #1440009
05/21/13 10:11 PM
05/21/13 10:11 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
the one i just put in my RR is in at 105, seems to be pretty happy there.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: installed centerline for .557 mopar cam? [Re: 68 HEMI GTS] #1440010
05/21/13 10:54 PM
05/21/13 10:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had the .557 in my old 906 headed 440 on a 104 centerline. Drove real nice and ran 11.49 @ 116 in my 3700 lb 63 on pump thru the pipes. Ron
Re: installed centerline for .557 mopar cam? [Re: 383man] #1440011
05/21/13 11:42 PM
05/21/13 11:42 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Thanks guys. I have the proper tools to degree the cam I just wanted to make sure 106* would be ok or I should just install it straight up. Thanks again, Can't wait to get this thing back together. The stock 906's have held this thing back long enough.
Re: installed centerline for .557 mopar cam? [Re: rck850] #1440012
05/22/13 10:03 AM
05/22/13 10:03 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I too vote for 104 install .
Re: installed centerline for .557 mopar cam? [Re: Dodgem] #1440013
05/22/13 01:37 PM
05/22/13 01:37 PM
Washington
SuperStock68Dart Offline
Washington
Yes...104
Re: installed centerline for .557 mopar cam? [Re: SuperStock68Dart] #1440014
05/22/13 03:45 PM
05/22/13 03:45 PM
organ
maximum entropy Offline
organ
i had a 557 in my 10.3:1 496 installed at 108, and it felt flabby down low. it was fast, but i'd definitely install that at LEAST 4° advanced. i changed to a 509, straight up, and it feels MUCH torqueer, and it's faster, too.
