Re: installed centerline for .557 mopar cam?
[Re: rck850]
#1440005
05/21/13 07:51 PM
05/21/13 07:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a Comp Cams magnum series timing set it allows 4* advance and 4* retarded is there any way to get only 2* out of it so I can just install it at Mopar's recommended centerline? It's a pretty mild combo 10.5cr with eddy heads, 3.72 gear and 3000 converter. all in a 3200lb duster.
Put it in at the 4* advanced BUT I would advise you to degree the cam... its too easy for the factory OR you to be off.. by degreeing it you KNOW where it is... if you dont have the equipment or dont know how then ask a buddy or take it to a shop.. they shouldnt charge you much ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1440007
05/21/13 09:30 PM
05/21/13 09:30 PM
Posts: 16,932 NC
440Jim
NC
I agree with Mr. P. Just because you put the timing chain set at +4 doesn't mean the cam is anywhere near that. And combo is important. But a typical combo suitable for that cam likes the -installed intake centerline 104-106 ATC. ![](/ubbthreads/images/graemlins/Twocents.gif) If the combo likes less than that, it is the wrong cam.
[Re: dennismopar73]
#1440008
05/21/13 10:10 PM
05/21/13 10:10 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
110 c/l cam I never like to go under a 105-106 install c/l, that's me . I would have rather bought a cam that was at 105 c/l , then put that one in at @ 102 c/l! That's just me thing,
So you would rather the cam company cuts the keyway with more advance rather than use an offset cam key? Basically your doing the same thing. Unless you are confusing lsa with icl. Keith
[Re: 68 HEMI GTS]
#1440010
05/21/13 10:54 PM
05/21/13 10:54 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I had the .557 in my old 906 headed 440 on a 104 centerline. Drove real nice and ran 11.49 @ 116 in my 3700 lb 63 on pump thru the pipes. Ron
[Re: SuperStock68Dart]
#1440014
05/22/13 03:45 PM
05/22/13 03:45 PM
Posts: 5,080 organ
maximum entropy
organ
i had a 557 in my 10.3:1 496 installed at 108, and it felt flabby down low. it was fast, but i'd definitely install that at LEAST 4° advanced. i changed to a 509, straight up, and it feels MUCH torqueer, and it's faster, too.
