Piston Weight #1438211
05/18/13 02:10 AM
05/18/13 02:10 AM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Does anyone know how much the TRW L2355F six pak pistons weigh? I can't seem to find a weight for them or the 440 source pistons (part# 4000). .030 over 440 Ross pistons appear to be 647-658 grams depending on what you select.
I am just curious how much of a weight difference there would be between the Ross and the TRWs...and how the 440 source pistons would compare.
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: Piston Weight [Re: tywebb2] #1438212
05/18/13 02:16 AM
05/18/13 02:16 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
TRW L2355F 872g 2.061" 4 valve reliefs
http://www.moparts.org/Tech/Archive/bb/59.html
Tony
70 AARCuda Vitamin C
Re: Piston Weight [Re: 70AARcuda] #1438213
05/18/13 02:45 AM
05/18/13 02:45 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Plus 250 grams for the pin if I remember, you are WAY better off with something a bit more up to date and a LOT lighter.
Re: Piston Weight [Re: 70AARcuda] #1438214
05/18/13 02:46 AM
05/18/13 02:46 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
So basically skip the grams & say each Ross piston weighs a half pound less than the TRW piston..
Which one will rev quicker? Which one will live longer? Which one is easier on the rod bolts...
Re: Piston Weight [Re: tywebb2] #1438215
05/18/13 03:31 AM
05/18/13 03:31 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sealed Power makes a light weight "LW2355F" piston, but it still weighs 773 grams, but only costs $409.39 /set and uses the 1/16" ring pack.
Re: Piston Weight [Re: 451Mopar] #1438216
05/18/13 10:00 AM
05/18/13 10:00 AM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Hmm...thinking about putting in 440 source h-beam rods and pistons when I freshen up the 440 later this year. Right now i have stock rods and the TRW L2355F pistons.
'72 440 Cuda
Re: Piston Weight [Re: tywebb2] #1438217
05/18/13 12:48 PM
05/18/13 12:48 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Pins go 225 to 230.
If you already have the TRWs use them. But for what they cost, the quality, and the weight, there are just a lot of better options out there IMO.
Re: Piston Weight [Re: BSB67] #1438218
05/19/13 02:18 PM
05/19/13 02:18 PM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
I know it is not exact the same piston, but I got the domed version inside (2295, .30 over) and
the pin should be the same. It weights 190,4g (average weight of all 8) and it was measured with a 3000$ lab scale.
The piston was 807g (in average) the snap ring was 5,6g (in average).
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Piston Weight [Re: Den300] #1438219
05/19/13 07:25 PM
05/19/13 07:25 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
The trw works well for a budget application, if you already have the piston or get them for very cheap. Yes a lighter piston is a much better option.
However the 440 bottom end is very robust and many many people have used the trw for years with great luck.
The rest of the combo you plan to build would be helpful.
Re: Piston Weight [Re: viperblue72] #1438220
05/19/13 11:38 PM
05/19/13 11:38 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Unfortunately, they are not even close to the pistons they once were.
Re: Piston Weight [Re: BSB67] #1438221
05/20/13 12:47 PM
05/20/13 12:47 PM
dogdays Offline
dogdays  Offline
Are they built in India now like many Sealed Power pistons?
The 440Source pistons are Icon, go to their website to find weights.
R.
Re: Piston Weight [Re: dogdays] #1438222
05/20/13 12:59 PM
05/20/13 12:59 PM
Are they built in India now like many Sealed Power pistons? R.
I had to call Spped Pro, TRW, AKA Federal Mogul on a replacement piston that came form India with the dry film coating on it, it was lighter than the originals in the motor The Rep. said all of the machines had been moved to India and alll of the thier pistons where now being made in India It looked like a cast piston on the insides NOT GOOD
Re: Piston Weight [Re: Den300] #1438223
05/20/13 01:09 PM
05/20/13 01:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The Domed TRW's were supplied with a thinner wall pin to keep the total weight close to the stock piston weight.
Re: Piston Weight [Re: JohnRR] #1438224
05/20/13 02:18 PM
05/20/13 02:18 PM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
aha, thanks for the info!
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
