Piston Weight
#1438211
05/18/13 02:10 AM
05/18/13 02:10 AM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
Does anyone know how much the TRW L2355F six pak pistons weigh? I can't seem to find a weight for them or the 440 source pistons (part# 4000). .030 over 440 Ross pistons appear to be 647-658 grams depending on what you select.
I am just curious how much of a weight difference there would be between the Ross and the TRWs...and how the 440 source pistons would compare.
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
Re: Piston Weight
[Re: tywebb2]
#1438212
05/18/13 02:16 AM
05/18/13 02:16 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Piston Weight
[Re: 451Mopar]
#1438216
05/18/13 10:00 AM
05/18/13 10:00 AM
tywebb2
super gas
super gas
Jarrettsville, MD
Hmm...thinking about putting in 440 source h-beam rods and pistons when I freshen up the 440 later this year. Right now i have stock rods and the TRW L2355F pistons.
Re: Piston Weight
[Re: BSB67]
#1438218
05/19/13 02:18 PM
05/19/13 02:18 PM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
I know it is not exact the same piston, but I got the domed version inside (2295, .30 over) and the pin should be the same. It weights 190,4g (average weight of all 8) and it was measured with a 3000$ lab scale. The piston was 807g (in average) the snap ring was 5,6g (in average).
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
Re: Piston Weight
[Re: Den300]
#1438223
05/20/13 01:09 PM
05/20/13 01:09 PM
Posts: 75,050 U.S.S.A.
JohnRR
U.S.S.A.
The Domed TRW's were supplied with a thinner wall pin to keep the total weight close to the stock piston weight.
