Window net question?? #1437334
05/16/13 10:01 AM
05/16/13 10:01 AM
Middletown, Ohio
Joes66dart Offline OP
Middletown, Ohio
We put a new chassis under the car this year and it has a funny car cage. The car will cert 7.50 but will probably only run 10.00 -10.30
I have been looking over the rules and seen that a net is required for 9.99 and faster but I have also heard that since we have a funny car cage that one is required no matter what the ET. Can anyone here clarify this for me.
Re: Window net question?? [Re: Joes66dart] #1437335
05/16/13 10:14 AM
05/16/13 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I cant answer your question for FACT but I am doing
the same thing with my Rampage... its a full tube
chassis but without the F/C cage ...I'm not even gonna
cert it since I can only run 10.0 without a license..
to me your just making a safer car but still under
the 10.0
Re: Window net question?? [Re: MR_P_BODY] #1437336
05/16/13 02:08 PM
05/16/13 02:08 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 70' Challenger is certed for 7:50 (25.5) also. Won't be running near that anytime soon at the rate I am going. Yes, a window net is required with a f.c. cage. Here is how we did mine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Window net question?? [Re: 6PKRTSE] #1437337
05/18/13 12:41 AM
05/18/13 12:41 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
If your car requires a cage, then a window net is also required, no matter what the ET is.
Re: Window net question?? [Re: loaderpro] #1437338
05/18/13 06:31 AM
05/18/13 06:31 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Are you sure on that? I'd ask the tech guy at your track!
http://www.northeastdragracing.com/showthread.php?9850-Window-net
Re: Window net
Originally Posted by Top452
If you are running in the 10s do you need a window net if the car has a cage.
Let's clear this up
Window nets you do not need a window net if you run 10.0 or slower
If you run 135 mph you need one.
Window nets do not have to be replaced if thay are ribbon type as long as there in good shape , the fish net ones have to be replaced every two years .
Pro classes must replace them in two years.
I hope this helps every one to understand this rule.
Buddy Scurto
Tech Director
NED
Re: Window net question?? [Re: MPerry] #1437339
05/18/13 10:16 AM
05/18/13 10:16 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The operative word here is "requires". If your running in the 10s you do not require a cage and therefore even if you have a cage a window net is not required. If you run a 9.99 you are "required" to have a cage and there are also "required" to have a window net. as mentioned above the exception is that if you run 135 or more in the 10s then you must meet the same requirements as if you were running in the 9s.
Re: Window net question?? [Re: Blucuda413] #1437340
05/19/13 02:52 AM
05/19/13 02:52 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
If you have removed the firewall, or replaced the flooring in your car with tin, you are required to have a full cage, and under that same rule a window net is then required. If the car is certed to run 7.50 it must use a window net regardless of Et or speed. Doubtful? Go to a track with one of these vehicles and attempt to get through tech without one.
Re: Window net question?? [Re: loaderpro] #1437341
05/19/13 07:01 AM
05/19/13 07:01 AM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Read my post above. That is a post from the head tech guy at New England Dragway in response to a similar question!(an NHRA track)
Re: Window net question?? [Re: MPerry] #1437342
05/20/13 12:14 AM
05/20/13 12:14 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
6:3 WINDOW NET
An SFI 27.1 ribbon-type or mesh-type window net is mandatory on
any full-bodied car required by the rules to have a roll cage. Window
net must be securely mounted on the inside of the roll cage, with
the permanent attachment at the bottom. All attachment points
must be designed in an attempt to protect the driver and avoid
contact with track surface or guardwall. Eyelet clips, dogleash
hardware, hose clamps, etc. prohibited. Penetration of webbing,
except as performed by manufacturer, prohibited. Any modification
to net must be performed by manufacturer.
ROLL CAGE
Roll cage mandatory in cars running 10.99 (*6.99) or quicker or any
car exceeding 135 mph. In full-bodied cars, with unaltered firewall,
floor, and body (from firewall rearward, wheeltubs permitted),
running between 10.00 (*6.40) and 10.99 (*6.99), roll bar permitted
