Re: Window net question??
[Re: Joes66dart]
#1437335
05/16/13 10:14 AM
05/16/13 10:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
We put a new chassis under the car this year and it has a funny car cage. The car will cert 7.50 but will probably only run 10.00 -10.30 I have been looking over the rules and seen that a net is required for 9.99 and faster but I have also heard that since we have a funny car cage that one is required no matter what the ET. Can anyone here clarify this for me.
I cant answer your question for FACT but I am doing the same thing with my Rampage... its a full tube chassis but without the F/C cage ...I'm not even gonna cert it since I can only run 10.0 without a license.. to me your just making a safer car but still under the 10.0
[Re: MR_P_BODY]
#1437336
05/16/13 02:08 PM
05/16/13 02:08 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
My 70' Challenger is certed for 7:50 (25.5) also. Won't be running near that anytime soon at the rate I am going. Yes, a window net is required with a f.c. cage. Here is how we did mine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: loaderpro]
#1437338
05/18/13 06:31 AM
05/18/13 06:31 AM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
If your car requires a cage, then a window net is also required, no matter what the ET is.
Are you sure on that? I'd ask the tech guy at your track!
http://www.northeastdragracing.com/showthread.php?9850-Window-net
Re: Window net Originally Posted by Top452 If you are running in the 10s do you need a window net if the car has a cage. Thanks Let's clear this up
Window nets you do not need a window net if you run 10.0 or slower If you run 135 mph you need one. Window nets do not have to be replaced if thay are ribbon type as long as there in good shape , the fish net ones have to be replaced every two years . Pro classes must replace them in two years. I hope this helps every one to understand this rule.
Buddy Scurto Tech Director NED
[Re: loaderpro]
#1437341
05/19/13 07:01 AM
05/19/13 07:01 AM
MPerry
Mopahts memba'
Mopahts memba'
If the car is certed to run 7.50 it must use a window net regardless of Et or speed. Doubtful? Go to a track with one of these vehicles and attempt to get through tech without one.
Read my post above. That is a post from the head tech guy at New England Dragway in response to a similar question!(an NHRA track)
[Re: MPerry]
#1437342
05/20/13 12:14 AM
05/20/13 12:14 AM
Posts: 197 Nor-Cal
loaderpro
Nor-Cal
6:3 WINDOW NET An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car required by the rules to have a roll cage. Window net must be securely mounted on the inside of the roll cage, with the permanent attachment at the bottom. All attachment points must be designed in an attempt to protect the driver and avoid contact with track surface or guardwall. Eyelet clips, dogleash hardware, hose clamps, etc. prohibited. Penetration of webbing, except as performed by manufacturer, prohibited. Any modification to net must be performed by manufacturer.
ROLL CAGE Roll cage mandatory in cars running 10.99 (*6.99) or quicker or any car exceeding 135 mph. In full-bodied cars, with unaltered firewall, floor, and body (from firewall rearward, wheeltubs permitted), running between 10.00 (*6.40) and 10.99 (*6.99), roll bar permitted
