Tire height for lowered trucks? #1435920
05/13/13 06:08 PM
05/13/13 06:08 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
Looking for the best tire height for a d150 with the 3" van lower control arms and the axel flipped on top of the springs in stock position.
Re: Tire height for lowered trucks? [Re: moparpollack] #1435921
05/13/13 08:00 PM
05/13/13 08:00 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
That depends on taste aswell. You can run 185/65-15s up the something in the 20" rims. Width and height is really your call. Some guys like 275/60-15s all the way around but I find it Hideous. A member on RCC has 30x9.50s and says they clear on his lowered Rc. I ran 205s to 225s on my clubcab with cut coils and my truck literally road on the bumpstop brackets.
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435922
05/13/13 11:03 PM
05/13/13 11:03 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have 255/70/15 in the rear & 225/60/15 & the rear is still 1/2" lower than the front & I have an axle flip with van LCA's & stock springs
Re: Tire height for lowered trucks? [Re: BulletBob] #1435923
05/14/13 12:02 AM
05/14/13 12:02 AM
85086
Lil Herman
Lil Herman
85086
I wanted the tires all the same size so I can rotate the tires. I have two new 255/60/15 that I was thinking of using. Maybe 225/70/15 as they are 27" tall.
Re: Tire height for lowered trucks? [Re: moparpollack] #1435924
05/14/13 12:11 AM
05/14/13 12:11 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
I have 275-60-15 rear and 255-60-15 fronts......for now
Re: Tire height for lowered trucks? [Re: chrisf] #1435925
05/14/13 12:13 AM
05/14/13 12:13 AM
85086
Lil Herman
Lil Herman
85086
Looks good is this with the van a arms and axel on top of the springs?
Re: Tire height for lowered trucks? [Re: moparpollack] #1435926
05/14/13 12:56 AM
05/14/13 12:56 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
sorry missed that part. cut coils and diff still in stock position
Re: Tire height for lowered trucks? [Re: moparpollack] #1435927
05/14/13 02:48 PM
05/14/13 02:48 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
29.5 x 15.5
Re: Tire height for lowered trucks? [Re: moparpollack] #1435928
05/14/13 07:47 PM
05/14/13 07:47 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
Front 235/60/17
Rear 275/60/17
Re: Tire height for lowered trucks? [Re: Kevin I] #1435929
05/14/13 08:29 PM
05/14/13 08:29 PM
85086
Lil Herman
Lil Herman
85086
Wow those are taller than I thought they would be.
Re: Tire height for lowered trucks? [Re: moparpollack] #1435930
05/15/13 09:26 AM
05/15/13 09:26 AM
scratchnfotraction Offline
I run 12" wide rim 29x15x15 M/T Sportsman SR radial.
a 7" wide rim 215/75/15 up front.
Re: Tire height for lowered trucks? [Re: scratchnfotraction] #1435931
05/17/13 03:03 AM
05/17/13 03:03 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Well I think Im finally going to work on much 80 shortbox those summer. Will need a mini tub. My dad called me a couple nights ago and said he had some wide tires. Now I have some 29x15.5 15s. Scratch what's your bs on your rim?
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435932
05/18/13 04:05 PM
05/18/13 04:05 PM
85086
Lil Herman
Lil Herman
85086
Snafu 8" wheels are to wide for most 60 series tires.
But took the truck for a drive and it was fun!
Re: Tire height for lowered trucks? [Re: moparpollack] #1435933
05/18/13 04:13 PM
05/18/13 04:13 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Nope. 275/60 calls for 10" (correction 9.5" for 17" Rims but summit only lists 2 tires)
An easy way to see what width rims a tire calls for is go to summitracing.com and search the size you want, click on it and read the specs. Same with tirerack.com but when you click specs it gives a list of that tire in diff sizes aswell
Summit you can also choose max widths etc in your search
Heres a start
http://www.summitracing.com/search/depar...e/passenger-car
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435934
05/19/13 09:24 PM
05/19/13 09:24 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I haven't measured the Rims yet but assume they are 12" wide with almost 7" bs. Here is why a tub would be required. Tires are 29x15.5-15
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435935
05/19/13 09:26 PM
05/19/13 09:26 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Another
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435936
05/19/13 09:27 PM
05/19/13 09:27 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Looks good from the rear
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435937
05/19/13 09:28 PM
05/19/13 09:28 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Last
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435938
05/19/13 09:32 PM
05/19/13 09:32 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Rims have to be installed backwards to fit a 5th Ave
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435939
05/19/13 09:34 PM
05/19/13 09:34 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
If want meant to haul my child that's due anytime now Id drop my 383 in it. Id run them.
