Tire height for lowered trucks?
#1435920
05/13/13 06:08 PM
05/13/13 06:08 PM
moparpollack
Lil Herman
Lil Herman
85086
Looking for the best tire height for a d150 with the 3" van lower control arms and the axel flipped on top of the springs in stock position.
Re: Tire height for lowered trucks?
[Re: BulletBob]
#1435923
05/14/13 12:02 AM
05/14/13 12:02 AM
moparpollack
Lil Herman
Lil Herman
85086
I wanted the tires all the same size so I can rotate the tires. I have two new 255/60/15 that I was thinking of using. Maybe 225/70/15 as they are 27" tall.
[Re: chrisf]
#1435925
05/14/13 12:13 AM
05/14/13 12:13 AM
moparpollack
Lil Herman
Lil Herman
85086
Looks good is this with the van a arms and axel on top of the springs?
[Re: moparpollack]
#1435926
05/14/13 12:56 AM
05/14/13 12:56 AM
Posts: 5,948 British Columbia
chrisf
British Columbia
sorry missed that part. cut coils and diff still in stock position
[Re: Kevin I]
#1435929
05/14/13 08:29 PM
05/14/13 08:29 PM
moparpollack
Lil Herman
Lil Herman
85086
Wow those are taller than I thought they would be.
[Re: scratchnfotraction]
#1435931
05/17/13 03:03 AM
05/17/13 03:03 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Well I think Im finally going to work on much 80 shortbox those summer. Will need a mini tub. My dad called me a couple nights ago and said he had some wide tires. Now I have some 29x15.5 15s. Scratch what's your bs on your rim?
[Re: 76dodgeboy]
#1435932
05/18/13 04:05 PM
05/18/13 04:05 PM
moparpollack
Lil Herman
Lil Herman
85086
Snafu 8" wheels are to wide for most 60 series tires. But took the truck for a drive and it was fun!
[Re: moparpollack]
#1435933
05/18/13 04:13 PM
05/18/13 04:13 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Nope. 275/60 calls for 10" (correction 9.5" for 17" Rims but summit only lists 2 tires) An easy way to see what width rims a tire calls for is go to summitracing.com and search the size you want, click on it and read the specs. Same with tirerack.com but when you click specs it gives a list of that tire in diff sizes aswell Summit you can also choose max widths etc in your search Heres a start http://www.summitracing.com/search/depar...e/passenger-car
