440 or 413? #1435684
05/13/13 11:33 AM
05/13/13 11:33 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Hi guys
I have one motor for rebuild and Iam bit confused as code what is stamped on passenger side of block is 3698830 what should be 440cid RB, BUT on right side of distributor there is surface where is stamped codes like:
416 .060
10.88
So what should I trust?
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: 440 or 413? [Re: Georg] #1435685
05/13/13 12:26 PM
05/13/13 12:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hi guys
416 .060
10.88
You dont trust either... measure the bores... I dont
remember what the bore was on a 413 but it looks
like the stamped number up front is a .060 over..
just measure it when you pull it apart
Re: 440 or 413? [Re: Georg] #1435686
05/13/13 01:15 PM
05/13/13 01:15 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
413 has a 4.18" bore
440 has a 4.32" bore
Re: 440 or 413? [Re: Georg] #1435687
05/13/13 01:19 PM
05/13/13 01:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I thought 440's all had 440 followed by a letter on the "pad"
Coming soon!!!!
Re: 440 or 413? [Re: Mr.Yuck] #1435688
05/13/13 01:59 PM
05/13/13 01:59 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
I measured bores and they are 4.34" but need to overbore. Seems its 440cid RB
Re: 440 or 413? [Re: Georg] #1435689
05/13/13 02:06 PM
05/13/13 02:06 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Whats it say on the casting side of block and what is casting date on side??? a 413 to go to 4.25 bore would have to have been bored .080.
JAKES AUTOMOTIVE
Re: 440 or 413? [Re: JAKE68] #1435690
05/13/13 02:37 PM
05/13/13 02:37 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
code is on passenger side 3698830 but I need to look the date tomorrow. If I remeber then year was 73 or 74
Re: 440 or 413? [Re: Mr.Yuck] #1435691
05/13/13 02:43 PM
05/13/13 02:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They would until you machine the info off , or it was an over the counter block that never had info stamped in it.
Re: 440 or 413? [Re: Georg] #1435692
05/13/13 02:47 PM
05/13/13 02:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have access to a sonic checker ?
Sounds like the valley end rails were machined and info by whomever did it stamped on there. A 413 bored to 4.340 would be bigger than 416. The 416 is probably a reference number by the rebuilder.
What is the date stamped on the back of the bearings ?
Also the 060 may not be an overbore indication , better yet the block may have been decked that much. I had a 69 440HP that had the valley end rails machined and it was just stamped 020. The block was .030 if I remember right , I figured out the block had been decked .020 .
Re: 440 or 413? [Re: Georg] #1435693
05/13/13 03:55 PM
05/13/13 03:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, that number represents a 73 to early 75 440
Re: 440 or 413? [Re: Sport440] #1435694
05/13/13 09:13 PM
05/13/13 09:13 PM
Lehigh Acres, Florida
rickstershemi Offline
Re: 440 or 413? [Re: rickstershemi] #1435695
05/15/13 02:31 AM
05/15/13 02:31 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
good, thanks!
